Reality check on shock and spring replacement for TRD
Discussion in '1st Gen. Tacomas (1995-2004)' started by spur0701, Nov 22, 2015.
  1. Nov 22, 2015 at 2:51 AM
    spur0701
    spur0701 [OP] New Member
    Great Falls, VA
    99 SR5
    Have a 99 Xtracab with TRD package, has 130K on it and still has the original OEM shocks (inherited from dad).......I use it for hunting and to haul wood from time to time....from the threads I've read I should be good to go with 5100s in the front and back, like these:
    http://www.suspensionconnection.com/view-cat/toyota/tacoma/1999?category=bilstein 5100 shocks
    Just making sure before I pull the trigger on them, anything I'm missing? I take it I should also replace the coils in the front, should I go with OEM or Eibach? Should I do rear leafs? If so what's a good recommendation or are Dorman's good enough? Thanks!
  2. Nov 22, 2015 at 7:54 AM
    Nowhereman04
    Nowhereman04 Well-Known Member
    Tar Hill Blue NC
    Silver 04 DC 4x4 SR5 TRD OFF ROAD
    Bilstein 5100's front, Bilstein 5125's rear
    If your not gonna lift the truck, go with 5125's in the rear. The 5125's are a direct replacement for the OEM shock.
