Really bad gas mileage
Discussion in '4 Cylinder' started by 4cyltacoma, Jan 26, 2011.
  1. Jan 26, 2011 at 10:36 PM
    4cyltacoma
    4cyltacoma [OP] Well-Known Member
    Reagan
    Fresno, Ca
    06 Tacoma SR5 4Cyl 4x4
    AFE CAI, Black Housed Headlights, In Channel Window Visor, Bug Deflector, Black Side Step Tubes, Blacked out emblems
    I own A 2006 tacoma access cab 2.7 4 banger 4x4. I have 80k + miles on the truck. Recently i been getting horrible gas mileage. I used to get 24-25 combined. And now im getting like 17-19 miles combined.
    I do my regular tune up. Changed to oil at every 3000 miles with syntheics. Changed my tranny fluid, differential fluid, spark plugs etc. But still getting really bad gas mileage. Can u help me out here. Maybe im forgetting something??
    I really need to do something fast cause its killing me here. I drive to work 50+ miles one way and im going down the drain with the mileage im getting. Thanks for all your input.
  2. Jan 27, 2011 at 2:11 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    air filter, tire pressure? make sure those are all g. seems like you've covered the rest...do you have winter blend gas where your at? i heard that can affect your gas mileage, although i would'nt know about that too much lol
  3. Jan 27, 2011 at 7:48 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    x2 on the air filter and tire pressure.
    How many miles are on the truck? If your over 100k, did you change the plugs with new iridiums? Are you carrying any extra weight that weren't before or have you gotten larger tires? Does it run rough, maybe it's time for some injector cleaner or seafoam treatment.
  4. Jan 27, 2011 at 8:04 AM
    schleygo
    schleygo Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    My 2001 was a 4cyl. I started getting real bad gas mileage, so I changed plugs, wires, air filter, cleaned MAF, oil change, etc. Still crappy mileage.
    I then read up further and changed an O2 sensor and my catalytic converter was partially clogged. After I changed those, I gained 2 MPG.
    If you put your hand close to your exhaust while running, and it is extremely hot, you could have a clogged catalytic converter. I'm talking you cant keep your hand there for 5 seconds. Use caution when checking.
  5. Jan 27, 2011 at 11:00 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    24-25 mpg combined (what you were getting before) is extremely good, almost something wrong in itself. But a 28% drop in fuel economy is pretty serious anyway. Winter blend gas can definitely hurt fuel economy, trust me. Other things like changing the grade of oil, forgetting to air the tires, brake drag, restricted intake or exhaust, etc etc. Just trying to think of things that may have been missed. And like another poster said, be sure you're using the iridium plugs and that the coil packs are firing properly. Good luck, and keep us posted if you find anything.
  6. Jan 27, 2011 at 12:43 PM
    danteisme
    danteisme Well-Known Member
    Vandergrift, PA
    06 DCSB Sport, 96 Integra GSR
    i noticed with my 4 banger that since winter has started, i'm down from my usualy 22-24 mpg to about 18-20. i blame that on the winter blend gas, or the fact that my truck has to run richer longer to get until it gets to operating temps.
  7. Jan 27, 2011 at 2:23 PM
    Al2006
    Al2006 Member
    VA
    06 Tacoma 4x4
    none
  8. Jan 27, 2011 at 2:47 PM
    afd23a
    The Dynamo of Dixie
    I've noticed the same.
  9. Jan 27, 2011 at 3:04 PM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    Check your o2 sensor and Cat converter.
    I got 23 mpg, then got the bright idea to str8 pipe my exhaust. TERRIBLE IDEA!! I avg 15 -16 mpg with it str8 piped. Needless to say I welded my Cat back on!!
  10. Jan 27, 2011 at 5:20 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check the brakes for sticking pistons and uneven wear. Dragging shoes and pads will chew up gas fast.
    Does your brake pedal pulsate while braking?
  11. Jan 27, 2011 at 9:59 PM
    4cyltacoma
    Reagan
    Fresno, Ca
    My air on my tires are good and so is my intake. I changed my cabin air filter also. And used nothing but synthic only on my oil.. Maybe ill ck on my cat and o2 sensor and the brakes. Thanks guys. If u reccomend anything else let me know. Thanks again
  12. Jan 27, 2011 at 10:01 PM
    4cyltacoma
    Reagan
    Fresno, Ca
    What do u mean my brakes pulsate?? Im not to big on wrds. XC... I know when i brake i have a slightly bad vibe from the back tires..
  13. Jan 27, 2011 at 10:02 PM
    4cyltacoma
    Reagan
    Fresno, Ca
    Idk if i have winter blend gas.. I live in fresno cali. So maybe i do???
  14. Jan 27, 2011 at 10:02 PM
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    Just this passed week I checked and I'm getting 12-14!:eek: I'm going to have to do full maintenance...
  15. Jan 27, 2011 at 10:21 PM
    4cyltacoma
    Reagan
    Fresno, Ca
    Dang. And i thought i was doing bad...
  16. Jan 27, 2011 at 10:26 PM
    Nightstr
    Felipe
    Sacramento CA
    05 prerunner sr5
    If got what you are getting I'd be golden.:D
  17. Jan 27, 2011 at 10:37 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    The mileage on my 4 cyl has dropped quite a bit here recently too. Like from around 24 to 19ish.
    I think its a combination of winter mix gas, and I need the 100,000 mile service.
    My filter is new, my air pressure is good, but I'm running on plugs with 103,000 miles on them...
    I hope to get it done soon.
  18. Jan 28, 2011 at 11:29 PM
    4cyltacoma
    Reagan
    Fresno, Ca
    man i think you really need to do a tune on your taco... Hope you can get better gas mileage soon..
    ooh and btw do you guys think that an exhaust will help save gas.. is it worth the buy??
  19. Jan 29, 2011 at 1:44 AM
    HomeGrown
    HomeGrown Well-Known Member
    Bill
    South Bend, IN
    2014 Reg Cab 4WD
    A header and free flowing muffler can generally give you a couple mpg ( if you can keep your foot out of it, that is :D ) but to do this strictly for mpg gain is fools journey, considering the up-front cost vs. payback time.
    If a few mpg less is seriously putting you "down the drain", you should consider a higher mpg vehicle with all the driving you do. You used to get 24-25 combined?!? What you're getting now seems to be closer to the norm. I don't think I ever got over 23 highway with my last Taco, which was a 4x4 reg cab.
  20. Jan 29, 2011 at 2:25 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Your brake pedal should be smooth with no vibrations when you apply the brakes. Warped rotors or drums will cause the vibration to be felt in the pedal. Warping can be caused by slow brake release which causes too much heat (sticking shoes, pads, pistons, guide pins). It can also be caused by a seized piston or guide pin, or overly agressive braking/two foot driving. Sticking and seizing are the worries for bad mpg, as far as brakes are concerned. The others are just poor driving habits.
    Check the brakes for problems. It's easy to see with the wheels off. Look for uneven wear of pads/shoes and bluing of the rotors/drums.
