REALLY CARSON CITY TOYOTA!?!?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98_3RZ_NIC, Feb 27, 2021.
  1. Feb 27, 2021 at 11:23 PM
    Allex95
    Allex95 Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    I only go to the dealer when it’s really out of hand and I think they can handle it better. That’s rare though lmao cause dealers are scammers
  2. Feb 28, 2021 at 6:57 AM
    98_3RZ_NIC
    98_3RZ_NIC [OP] Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    because I am not mechanically inclined. I was barely able to replace all my suspension by myself. No way was I going to try and attempt water pump, oil pump and crankshaft seal. It’s my daily driver now that I sold my Corolla. I needed it done in one day.
  3. Feb 28, 2021 at 7:14 AM
    Glamisman
    Glamisman Well-Known Member
    you sold your Corolla... those 1st gen tacomas and camrys are lifetime vehicles.
    My cousin is a service manager at a Hyundai / Subaru dealer and he tells me that it might take a day sometimes just to get oil changed... the techs are salary and small commision and just dont care. Sure you can fire them and replace them with what, more of the same? I told him that when I retire I will come in and be your oil change guy and only your oil change guy and I will work 100% commission. When I started out at a Toyota dealer doing oil changes on commission I was flagging more than the brake and tune up guys were.
    Kevins60 and 98_3RZ_NIC[OP] like this.
  4. Feb 28, 2021 at 7:18 AM
    98_3RZ_NIC
    well they seemed to work on my truck like it was their own. I poked my head under when I picked it up and checked the oil pump and water pump out and they were all nice and shiny and new. So hopefully the leak is fixed. Parts replaced have a one year warranty by the dealer so if they start to leak I can take it back in.
  5. Mar 1, 2021 at 1:25 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Find a competent independent mechanic. With google reviews, Yelp, Facebook, etc. these days it’s not hard to narrow down the best ones in your area. Dealerships typically staff techs good enough to read a scanner and do basic jobs. I’ve had a dealer install a leaf spring bolt the wrong way so it was gouging the shackle and then forget to put a nut on the front leaf spring bolt after I brought it back to have them undo the stoopid the only time my truck went to one for the recall leaf springs. Recently a family friend brought his 99 Mazda / Ford Ranger to a Mazda dealership and they “diagnosed” a broken fuel pump and were going to bill him $1100 to replace it.
    He was broke enough to not make a $1100 repair on a $3000 truck so he asked me if I could do it. I replaced the pump stupidly without turning the key and seeing if it primed the fuel lines. If I had I would have heard it turn on for 2 seconds. Long story short, replaced the fuel pump with another one he bought, still wouldn’t start, confirmed both new and old fuel pumps worked and engine was getting fuel pressure and spark plugs getting signal. Reach in the timing cover and the timing belts not even on the cam pulley.
    Those morons would have charged my friend $1100 to replace a fuel pump that’s working on a $3000 truck with a broken timing belt AND then charged him whatever they wanted for the timing belt repair ($18 part mind you).
    I know there’s a few good techs scattered about dealerships, but you might as well expect someone with the same intelligence as a jiffy lube oil slinger for the most part at dealerships. The couple times I’ve had a vehicle go there it’s been a complete joke.
