REALLY! Do I have to get UCA's for bilstein 5100 and eibach springs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JPA2002, Aug 22, 2014.
  1. Aug 22, 2014 at 2:31 PM
    JPA2002
    JPA2002 [OP] Well-Known Member
    Roanoke, VA
    2021 DCSB TRD Pro
    So I took my truck to the alignment shop after installing my eibach and 5100's on the front, and that was an experience. They couldn't get it aligned within spec, and the steering wheel is now off. So does this mean that I have to get new UCA's? If so, are there some adjustable ones? What does everyone recommend?
    Thanks
    Jon
  2. Aug 22, 2014 at 3:02 PM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    What's the alignment print out show?
    What setting are you using on the 5100s? I'm pretty sure anything under 2-2.5" is fine on stock UCA's. Anything over 2.5" should look into new UCA.
  3. Aug 22, 2014 at 3:20 PM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    I think they said 3.1. They didn't give me a print out. I am going over tomorrow to get it
  4. Aug 22, 2014 at 3:28 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Yes you need new UCAs with 3" of lift or more. That's normal. The new dimensions put out by the coil overs cannot line in spec with stock UCAs.
  5. Aug 22, 2014 at 4:50 PM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    It is 5100s set at 0 and then the eibachs? Toyota must build these with a narrow adjustment window.
    Jon
  6. Aug 22, 2014 at 5:02 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Suspension section??
  7. Aug 22, 2014 at 5:13 PM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    Sorry. Moderator, please move the thread.
    Regards,
    Jon
  8. Aug 24, 2014 at 3:25 PM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    Total chaos uca's ordered!
    More money!!!
    Jon
  9. Aug 24, 2014 at 3:35 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Sounds like a shitty alignment shop. Particularly since the steering wheel isnt even straight. You shouldnt have any problems getting into spec with stock UCA'S. I was inspec with my setup. Got LR UCA's to see what all the rage was about and have no difference in handling. Waste of money for a 2.5 lift.
    Jukeboxx13 likes this.
  10. Aug 24, 2014 at 3:51 PM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    That is what I thought. Hell, I only got roughly 1.5" of lift with the 5100 on zero and the toytec eibachs. There are only the two lower control arm adjustments, correct.
    Let's just say they are getting a visit tomorrow and I expect a full refund and I will be going to a more trusted source.
    Jon
  11. Aug 24, 2014 at 3:54 PM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    They should have had it ready for you when they were done. I got a lifetime alignment when I put my 5100s and OME 886s on. Definately take it somewhere else.
  12. Aug 24, 2014 at 3:59 PM
    Rockdwg
    Rockdwg Well-Known Member
    Rapid City, South Dakota
    2008 Tacoma DCSB trd off road
    so I just picked up a 2008 DCSB Tacoma, was curious I see a lot of UCA talk on here are the stock ones bad or is it a must have for lift kits?
    thinking right now all I really want to do is get a leveling kit. just want the truck to sit flat instead of Nose down for now. with a leveling kit guessing around the 2inch mark what is the max tire size I can go?
  13. Aug 24, 2014 at 4:03 PM
    hitmans.army
    Myrtle Creek, OR
    I'm not an expert, but UCAs are hit and miss when it comes to lifting. Some people need them after "3 inch" lift, some don't. Same for carrier bearing drop. I was fortunate enough not to need them and Discount Tire was able to get my alignment done without issues.
  14. Aug 24, 2014 at 4:09 PM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    This is killing me! I cannot believe some of you are able to get the alignment in spec without new uca's.
    I mean, all I basically added was longer springs that should have only given me about 1.6" of lift.
    Has anyone had the same experience as me?
    Jon
  15. Aug 24, 2014 at 4:11 PM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    That is all I wanted also, and here I am buying new upper control arms.
    I just wanted my truck level, and it is going to end up costing me a fortune.
    I want it right, as I don't won't tire wear.
    Jon
  16. Aug 24, 2014 at 4:12 PM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    Just my luck!!!
  17. Aug 24, 2014 at 4:27 PM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    the issue is insufficient caster. low caster settings don't affect your tire wear, they make your truck handle poorly. typically shops can get toe and camber in spec, but at the expense of caster.
    if you don't care if your truck wanders at highway speed or mind bump steer, you can skip the UCAs
  18. Aug 24, 2014 at 4:35 PM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    Thanks to everyone! I want it right, so I will install the uca's. That way if I ever want to go higher, I should be set.
    Jon
  19. Aug 24, 2014 at 5:17 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    At 1.6 you shouldn't need them. I'm at 1.75 on stock ucas with no problems. Now my last tacoma I had at 2.5", and the proper caster could not be achieved on stock ucas.
  20. Aug 24, 2014 at 8:01 PM
    dozer63
    dozer63 Well-Known Member
    Currently Homeless
    Renting moms car
    I installed 884's on 5100's set at zero. Lifted my truck over 3" but I have a regular cab 4X4 auto. It could not be aligned. It has been put back stock but I still have the thoughts of installing billies set at 1.75 on stock springs.
