Really dumb tire question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chucktown, Oct 15, 2015.
  1. Oct 15, 2015 at 12:06 PM
    Chucktown
    Chucktown [OP] Member
    I want to put larger tires on my 2005 DC TRD Sport (5' bed). I do not want to put a lift on it.
    From reading I believe I can put 265/70/16 without a lift?
    Will the 265/70/16 fit on the rims I currently own or will I have to buy new rims? If so what size?
    Will doing this greatly decrease my mileage?
    Will it increase rollover potential?
    Thanks for the help guys!
  2. Oct 15, 2015 at 12:08 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    It'll fit if you have 16" rims.
  3. Oct 15, 2015 at 12:13 PM
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
    I have cooper 265/75/16 ATPs on my tacoma and they fit great.
    My average mpg is 18
    On highway I have had an average of 20 mpg if i don't break 75, if I do 80-85 it's 17-18
  4. Oct 15, 2015 at 12:14 PM
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    I think mine came stock with those tires.
  5. Oct 15, 2015 at 7:17 PM
    Chucktown
    I think the TRD comes with 17" but i'll know more tomorrow. What does OEM stand for? I keep seeing it on the site.
    Any suggestions on tires?
    If i have to get rims, any suggestions on those as well?
  6. Oct 15, 2015 at 7:47 PM
    RickG
    RickG It seemed like a good idea at the time...
    Southern NH
    2010 SR5 4x4 Pyrite Mica
    Color matched grille, Access tonneau, OEM Temp/compass, De-badged, OEM hitch, Custom rear storage/dog deck, LED foot well lighting, Illuminated 4x4 switch
    I have a set of 265/70-16 Michelins M/S2 on mine that replaced the original 245/75-16s that came on it. The Tire Size Calculator suggests that they're nearly the same diameter, so the speedometer error is minimal. (...going by GPS, mine was wrong before I switched; now it's about 1 mph off in the other direction). They fit just fine with no lift, no rubbing anywhere, and look a ton better. No noticeable change in mileage, although they are probably a bit heavier. No need to be any more concerned with rollover than with stock; they're no taller. I could be wrong, but I think TRD/ORs come with 265's.
  7. Oct 15, 2015 at 8:13 PM
    smd3
    smd3 Well-Known Member
    265/70/16 is the factory tire for the TRD Off Road, it is the same overall diameter as the stock tire and 17" wheel combo that came on the TRD Sport, which I think was 265/65/17.
    If you want to upsize by one size you need to go 267/75/16 or 265/70/17.
    Island Cruiser likes this.
  8. Oct 15, 2015 at 10:10 PM
    Pigpen
    Dan
    Northwest Montana
    FTFY
    smd3[QUOTED] likes this.
