Really hard re-start - cold weather
Discussion in '3rd Gen. Tacomas (2016-2023)' started by soggyBottom, Feb 4, 2024.
  1. Feb 4, 2024 at 2:39 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    2018 has 55k miles on it. The temperature was 23f (-5c). On the initial start, it was a little sluggish but was fine. About a minute later I stopped the engine, then tried to restart, and it wouldn't start even after multiple 5 to 10 sec tries. Engine would turn but no ignition
    I shut it off, waited about a min, tried again with success.
    I remember a
    Something similar happening with an old carbureted truck I had years ago. What causes this?
  2. Feb 4, 2024 at 2:47 PM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    Crank no start? No crank no start? Slow crank no start?
  3. Feb 4, 2024 at 2:52 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    If you have a volt meter, is the battery voltage close to 12.6 volts with the engine off?
    Chew likes this.
  4. Feb 4, 2024 at 2:52 PM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    How old is your battery? It takes some time for the battery to recover (with the alternator charging it). Let the truck run at least 10 minutes, prior to shutting it off and then re-attempting
    Junkhead and Chew like this.
  5. Feb 4, 2024 at 3:08 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Very similar thing happened to me a couple of weeks ago. But it was -30F/ -35C. Only 3000 mi on mine. Turned out battery was bad and needed replacing. I'll bet that's what you need.
    Ronk44, Chew and Gfenza89 like this.
  6. Feb 4, 2024 at 3:16 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Definitely start w battery. I avoid starting cold and shutting off right away, as you’ve drained the battery, not warmed the engine, and haven’t recharged the battery.
    Junkhead, YF_Ryan and TA2016 like this.
  7. Feb 4, 2024 at 6:30 PM
    soggyBottom
    Crank speed was fine but no start
    Chew likes this.
  8. Feb 4, 2024 at 7:12 PM
    canuck guy
    Alberta
    23TRDOR
    If crank speed was ok then maybe you have some bad fuel in the system. Try putting in 8 oz of methyl hydrate or wood alcohol if your tank is half full or more. If there is water in the fuel this will dissipate it. Wait a few minutes and try again. Another reason to keep gas tank at least 1/2 full or more especially in cold weather.
  9. Feb 4, 2024 at 7:25 PM
    soggyBottom
    I think I was 3/4 tank today when this happened. I got gas yesterday from Sam's club.
  10. Feb 4, 2024 at 7:29 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Spark plug time, maybe
    Bishop84 likes this.
  11. Feb 4, 2024 at 7:31 PM
    Bishop84
    Bishop84 Well-Known Member
    My first thought, along with a throttle clean would be my first action depending on history and miles.
  12. Feb 4, 2024 at 7:34 PM
    TA2016
    Oregon
    Was there a tanker truck at Sam’s Club filling their underground tanks while you were there? If so, there could have been sediment stirred up while you were getting gas.
  13. Feb 5, 2024 at 5:41 AM
    BlackCat81
    2023 Ice Cap TRD OR
    You make no mention of the year, but 2017-2020 have a low pressure fuel pump recall and the first line of the introduction is “some 2014-2020 Toyota vehicles may exhibit a hard start and/or MIL ON……..”
    TSB 0009-23
    Chew likes this.
  14. Feb 5, 2024 at 9:22 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    It's probably not battery related then, sorry.
  15. Feb 5, 2024 at 11:38 AM
    canuck guy
    Alberta
    23TRDOR
    There might have been condensation/water in the tank /system before you got fuel. There might also have been water in the fuel you got at sams. Seems like too much of a coincident that's when you started to have problems. Like I said before try adding some alcohol. The 100% kind not the kind you can drink. What can it hurt. Just sayin and trying to help.
  16. Feb 5, 2024 at 12:14 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    X2.
    Some of my customers live like 2-3 mins away. I purposely go for a ~10 min drive to charge the battery and so my engine gets up to operating temps.
    Chew[QUOTED] likes this.
  17. Feb 5, 2024 at 12:31 PM
    canuck guy
    Alberta
    23TRDOR
    see post #7
  18. Feb 5, 2024 at 12:41 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If this has happened only once, I would file it away and move on.
    Junkhead likes this.
  19. Feb 5, 2024 at 12:48 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I was replying to Mr Chew’s post sir.
  20. Feb 5, 2024 at 12:52 PM
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    Could be flooded. Next time push gas peddle while cranking and release as soon a engine catches or don't shut off initial cold start until combustion chambers clear.
