Really need vibration help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Inverno4, Oct 11, 2013.
  1. Oct 11, 2013 at 9:44 AM
    Inverno4
    Inverno4 [OP] Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    Currently have issues that I think are related. First is a grind/rubbing that can be felt on the floor right at the tipping point of gas pedal and no gas pedal Its mostly when decelerating. Its not constant, just a second or so of something underneath. Secondly, got a vibration that happens at most speeds off and on, more noticeable at higher speeds. My buddy and I checked everything in the drive train, felt good. Here is what I've done to it in the past few months:
    - got new tires put on with alignment
    - installed new CV axle on the driver's side (NAPA reman)
    - new u-joint that had slight play
    - installed the ECGS front diff bushing for 1st gens, similar to this link: http://www.tacomaworld.com/forum/2n...nt-differential-bearing-vibration-thread.html
    Got a kid on the way in less than 5 months, need to figure out soon if we're going to keep this truck or not.
  2. Oct 11, 2013 at 11:06 AM
    MRBOND101
    MRBOND101 TTE
    Dylan
    Frisco, Texas
    16 TRD-OR AC
    Hmmmmmm is it like a violent vibration when coming to a stop?(shaking the truck) Or is it happening both when you decelerate and accelerate?? Ive been having a similar issue it sounds like...except without any of the grinding.
  3. Oct 11, 2013 at 11:09 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    its an extra cab so its probably not big enough to hold the little one in a car seat. trade it in for a 2nd gen dcsb and enjoy
  4. Oct 11, 2013 at 12:32 PM
    Inverno4
    Baltimore, MD
    2020 DC Off-Road MT
    Not violent but noticeable on the floor on deceleration especially. Ever fix yours or find what it may be?
    Found a baby carrier that fits in the back already so should be ok with keeping it.
  5. Oct 11, 2013 at 2:03 PM
    MRBOND101
    MRBOND101 TTE
    Dylan
    Frisco, Texas
    16 TRD-OR AC
  6. Oct 11, 2013 at 2:21 PM
    MRBOND101
    MRBOND101 TTE
    Dylan
    Frisco, Texas
    16 TRD-OR AC
    I had a slight vibration similar to yours but once I got my new shoes and an alignment havent felt it since..maybe someone else will be able to give some more insight hope you resolve it man!
  7. Nov 8, 2013 at 3:25 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    So I've got a vibration like the first one you mentioned. Mostly noticeable while coasting/decelerating and specifically between 25-35mph. Its a slow, rhythmic "whomp, whomp" generally about 2 seconds apart, doesn't really change when I apply the brakes.
    I just replaced some badly warped rotors and thought that was the cause of the problem, but it persists. I just rotated my tires also.. maybe I need to get them rebalanced and an alignment..
    any thoughts on this guys?
  8. Nov 8, 2013 at 4:00 PM
    Inverno4
    Baltimore, MD
    2020 DC Off-Road MT
  9. Nov 9, 2013 at 6:22 AM
    TIPICOTACO
    Tyler
    nw nj
    hmmm thanks, that does seem alot like whats going on w/ mine..
    This morning when it happened I popped it into 4hi and it went away immediately, it also does not occur at higher speeds.
    Inverno4 - how did you fix your problem?
  10. Nov 9, 2013 at 8:49 AM
    Inverno4
    Baltimore, MD
    2020 DC Off-Road MT
    If you read further into the thread, East Coast Gear Supply developed a fix. You have to call about 1st gens, it's not on the website I don't think.
  11. Nov 9, 2013 at 11:02 AM
    TIPICOTACO
    Tyler
    nw nj
    oh ok, I thought that ECGS only offered a 2nd gen fix.. (thats a loooong thread lol)
    I just took a look at my front diff and DS checking for play, and noticed that the slip yoke has some terrible looking grease coming out of it!! like chocolate pudding! I grease the zerks religiously but maybe a seal is bad or something allowing water in.. idk. I'l look into it more tomorrow and cal ECGS on Monday, thanks
