really really bad vibration
Discussion in 'Technical Chat' started by vaspeedjunkie, Nov 5, 2011.
  1. Nov 5, 2011 at 10:37 AM
    vaspeedjunkie
    vaspeedjunkie [OP] Member
    stock
    Ok i just want to say hi first. My name is brandon and I have a 06 tacoma prerunner. The truck is bone stock and I love it. Well i noticed a driveline vibration a couple weeks ago but it seem to go away so I didnt think anything of it. Well a couple days ago my wife was driving it and say man this truck is running really bad. well I get in it and the vibration is awful! I feel like im on my riding lawnmower lol. It vibrates no matter what the speed is. I can be running at 55mph and throw it in Netural and the virbration goes away. Im thinking it might be the u joints or carrier bearing. Its so bad we're not even driving it right now until we figure it out. Do the u joint or carrier bearing really go out at 75k miles on these trucks? we have had it since it was new and this is the first problem we have had with it. hoping you guys could help. remember it is bone stock access cab 2wd automatic. thanks in advance.
  2. Nov 5, 2011 at 11:12 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    so it goes away when u put it in nuetral.... is it rotational like, with speed does the frequency increase? check ur u joints, and carrier bearing. if its so bad, it should be easy to find what the problem is
  3. Nov 5, 2011 at 11:20 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You are supposed to tighten the driveshaft bolts and lubricate the U-joints every year or 10K. Was that ever done?
  4. Nov 5, 2011 at 1:27 PM
    vaspeedjunkie
    stock
    its seems to increase with rpm. I just dont want to start replacing stuff and it not be the problem.
  5. Nov 5, 2011 at 1:29 PM
    vaspeedjunkie
    stock
    bolts are tight.
  6. Nov 5, 2011 at 1:44 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    if it goes away when put in nuetral tho thats weird. cuz everything is still spinning trans back...
  7. Nov 5, 2011 at 3:46 PM
    Tacoma Mike
    Southern Maine
    He's taking the pressure off the joints in neut. So they are kinda floating.
    If it's that bad you should be able to find the problem fairly easy.
    Chock the tires and put it in neut (not running) and crawl under it and start shaking and twisting the drive shaft. Check the joints as you do this for slop.
  8. Nov 5, 2011 at 3:50 PM
    skunk
    skunk what did I miss?
    Rudi
    SoCal
    2010 TRD 4x4 (STOLEN)
    YOU WILL BE MISSED Satoshi Grill, FX-R retros, husky liners, bed bolt d-rings, TRD short throw shifter, 2.5 Fox Coil overs, AP UCA's, AP Expo rear leaf with Fox 2.0 shocks, Extended SS brake lines, AP kick-out sliders, 265/75/16 on Konig Countersteers, AllPro Apex front bumper and Zip Ties.
    maybe the balance weights flew off the shaft?
    :notsure:
  9. Nov 5, 2011 at 6:28 PM
    vaspeedjunkie
    stock
    ok mike i will check that out, thanks. also it looks like the weights are still there but who knows, they could have fell off. im just trying to figure it out before i just start throwing money at it.
  10. Nov 5, 2011 at 6:29 PM
    vaspeedjunkie
    stock
    also i checked the the carrier bearing and it looks good.
  11. Nov 5, 2011 at 6:39 PM
    Tacoma Mike
    Southern Maine
    Absolutely Brandon
    If you don't see anything get another set of eyes to look at it.
  12. Nov 5, 2011 at 6:39 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    PreRunners have sealed u-joints, they can't be greased.
  13. Nov 5, 2011 at 6:41 PM
    Asgard
    OP, my first u-joint went bad at 30k and the second at 85k. What u describe sounds like a bad u-joint, do u hear any squeaking ?
  14. Nov 5, 2011 at 7:39 PM
    vaspeedjunkie
    stock
    yes i hear squeaking and clunking sometimes.
  15. Nov 5, 2011 at 7:40 PM
    vaspeedjunkie
    stock
    so ur leaning towards the u-joints being bad mike?
  16. Nov 5, 2011 at 7:42 PM
    Tacoma Mike
    Southern Maine
    HEHEHE my son texted me yesterday and his truck is starting to squeak.
    Guess what I'm doing tomorrow. :frusty: So much for my day of rest lol
    With the squeaking like Chris mentioned i'd be looking there yes.
