Rear 02 sensor on 2002 2.4l
Discussion in '1st Gen. Tacomas (1995-2004)' started by Icecoast, Jun 9, 2023.
  1. Jun 9, 2023 at 4:17 PM
    Icecoast
    Icecoast [OP] Active Member
    Does anyone know if there's a replacement or compatible rear O2 sensor that uses a standard m18 x 1.5 bung. I welded up a 2.5" exhaust for my truck and I was hoping there was something I could use that didn't require the 2 bolt flange.
  2. Jun 9, 2023 at 9:13 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I have seen them around you just need to look.
    I found the 2 stud bungs easy to find so I never really looked for the threaded style.
  3. Jun 10, 2023 at 7:45 AM
    Icecoast
    I've searched a bit and think I'm just gonna pick up a narrow band 4 wire denso with the right plug and see what happens, just wondered if anyone already did this and had a known good part to start with. I currently have the original sensor plugged in and tied off to the frame but I'm still getting P0136: O2 sensor Circuit Bank 1 sensor 2.
