Rear 5.29 Gears Only
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kylea0917, Feb 19, 2025.
  1. Feb 19, 2025 at 12:00 PM
    kylea0917
    kylea0917 [OP] Member
    Yes, another rear gear thread unfortunately. Not to intended to waste anyones time but I am having a hard time finding full kits for 5.29 gears (gear sets and applicable hardware) for the rear only. It seems like everything I can find online is either just the rear gear with no hardware, or the full 4x4 (front and rear) that comes with the hardware. I have searched all over this forum and most threads with a good source had a link or company that is no longer around. Any ideas? (of course ill post this and someone will find a good source online in 28 seconds)
  2. Feb 19, 2025 at 12:21 PM
    svendough
    svendough Well-Known Member
    Colorado
    2020 Cement DCSB OR
    Skinny rubber, Bilstein lift, iKamper
    What do you mean by hardware? The truck has all of the bolts you'd need to swap out a diff. Not really sure what you're asking for but you can order a regeared diff (front or rear) from ECGS, remove old diff, put new one in, done.
  3. Feb 19, 2025 at 12:27 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    ^ Yeah, just do a swap with ECGS. Easy peasy.
    BabyBilly likes this.
  4. Feb 19, 2025 at 12:50 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    If you own a 4x4 then you're gonna have to do both front & rear OR never put it in 4WD again. They kind gotta match revolutions ya know.
  5. Feb 19, 2025 at 1:08 PM
    kylea0917
    Bearings, spacers, etc
  6. Feb 19, 2025 at 1:08 PM
    kylea0917
    no 4x4
  7. Feb 19, 2025 at 1:10 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    They sell gears as either full 4x4 kits (all install parts plus all gears for both diffs), or they sell it all itemized meaning a master install kit by itself, a R&P kit by itself, etc.
    You need to order a R&P for your diff and also a master install kit for your diff. Or order a pre assembled diff like from East coast gear supply or similar.
  8. Feb 19, 2025 at 1:15 PM
    kylea0917
    thank you!
