rear 5100 install
Discussion in 'Suspension' started by bunsojr, Jun 9, 2012.
  1. Jun 9, 2012 at 2:02 PM
    bunsojr
    bunsojr [OP] Well-Known Member
    Northern California
    2005 Silver DCLB
    Bilstein 5100s with OME 885 Medium Duty Dakar Leaf Springs SPC Upper Control Arms Pro Comp 7032 wheels BFG AT K02 in 275/70/17
    how do I prevent the things from spinning when I install the top nut? there's nothing to grab onto with a 2nd wrench. what did u guys do?
  2. Jun 9, 2012 at 2:07 PM
    bunsojr
    Northern California
    2005 Silver DCLB
    and how far do I need to screw down the nut
  3. Jun 9, 2012 at 4:58 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Slide the black protective boot down and grab it with a second wrench :cool:
  4. Jun 9, 2012 at 5:59 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    At the top of the shock there is a space for a 5mm allen wrench. Insert a 5mm allen and use an open ended box wrench to tighten the lock nut down.
