Rear a Tad Stff: Fox 2.0 with Resi and Icon Progressive AAL
Discussion in 'Suspension' started by Adventure4x4, Dec 9, 2016.
  1. Dec 9, 2016 at 6:45 AM
    Adventure4x4
    Adventure4x4 [OP] Well-Known Member
    Adam
    San Antonio, TX
    2013 TRD off road MT
    So I installed the Fox 2.0 Performance shock with the external reservoir with the icon 3 leaf progressive pack about 2 months ago and I feel that the rear end is just a tad too stiff. It tends to bounce off road and on road over potholes and speed bumps. The bed is also unloaded which was my first thought for the reason to the problem. Can’t complain about the flex though. I have been doing some research and coming up with mixed answers. Is it the 3 leaf pack or the shock or could it be a combination of both? Could I just add some weight to the bed? I also thought that maybe the tires could have an influence on the ride? Is it the lack of droop since the rear is lifted 1.5”? Any input would be appreciated. Trying to figure out which path to take. Thanks
    Also, the overload leaf was removed. I do not tow anything and when I have cargo in the bed it is not a substantial weight.
    My truck is a 2015 4 cyl access cab.
    The front Fox 2.0 coilovers do pretty well even with the lighter front end. Off topic question: Do you think if I bring down the ride height in the front a 0.25”, is that enough to feel a difference?
  2. Dec 9, 2016 at 6:50 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    What tire load range?
    What psi?
    What else was changed?
    Did the rear hop around before these changes?
    Bone stock even the shocks are a limiting factor, running the extended length 5100s fro downsouthmotorsports gained me a ton of droop and the smoothist ride, but the uptravel is limited and bumpstoos have to be reworked.
    Now im on the reg 5100s, icon, 4 leaf pack with overload removed, and its much smoother than stock and doesnt hop around.
    Small toolbox (kobalt shallow), with maybe 50lbs in it.... wrangler authoritys load range c, 265/75/16.
    ChadsPride likes this.
  3. Dec 9, 2016 at 6:52 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Prepare for the "its a truck" replies
    Taco Addiction likes this.
  4. Dec 9, 2016 at 6:54 AM
    Adventure4x4
    Adam
    San Antonio, TX
    Yep I'm ready for it haha.
    I have the Falken A/T3w P265/75r16 at 37 psi
    ChadsPride[QUOTED] likes this.
  5. Dec 9, 2016 at 6:54 AM
    inwood customs
    Dave
    Should not be a rough ride with that aal.
    Talk to someone at dsm about the shocks maybe..... im not sure how to check them, i hear sometimes new shocks come defective....iirc Sonny had some Kings come in brand new defective.
  6. Dec 9, 2016 at 6:56 AM
    inwood customs
    Dave
    Hmm, i run 36 on road and it seems fine.
    Id def call around a few REPUTABLE shops that work on shocks.... not just some place that installs or sells only.
  7. Dec 9, 2016 at 6:57 AM
    inwood customs
    Dave
    Was the aal and foxes installed at same time?
    ChadsPride and Adventure4x4[OP] like this.
  8. Dec 9, 2016 at 6:59 AM
    Adventure4x4
    Adam
    San Antonio, TX
    Yeah installed them at the same time. If I installed the shocks first, I could have felt the difference, but unfortunately not.
  9. Dec 9, 2016 at 7:01 AM
    Adventure4x4
    Adam
    San Antonio, TX
    I'll give them a call and see what they say. Thanks for the input
  10. Dec 9, 2016 at 7:01 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    37 is high.
    Drop down to 33 and see if it helps. I ran the same 3 leaf and had no complaints of the ride, though it is stiffer than stock and I knew and expected it.
    GDT and ChadsPride like this.
  11. Dec 9, 2016 at 7:02 AM
    ChadsPride
    agreed
  12. Dec 9, 2016 at 7:05 AM
    inwood customs
    Dave
    Ok, u see were i was going... damn
  13. Dec 9, 2016 at 7:08 AM
    Adventure4x4
    Adam
    San Antonio, TX
    Is that enough that it will negatively affect tire wear on the road, though?
  14. Dec 9, 2016 at 7:11 AM
    T4RFTMFW
    No, certainly no more than 37.
    I run 34. Falken suggests 29 for that tire.
  15. Dec 9, 2016 at 7:15 AM
    inwood customs
    Dave
    Chalk line test
  16. Dec 9, 2016 at 7:17 AM
    T4RFTMFW
    I wouldn't bother with that unless the problem goes away with a PSI drop.
    According to Falken he's 25% over inflated. So start there and run a normal pressure. If it doesn't go away, check your shocks. If it does, do a chalk test.
    YouTube has videos.
    Taco Addiction and ChadsPride like this.
  17. Dec 9, 2016 at 7:21 AM
    Adventure4x4
    Adam
    San Antonio, TX
    How did
    How did you find the recommended tire pressure? The max (cold) is 44 psi
  18. Dec 9, 2016 at 7:22 AM
    T4RFTMFW
    @DrFunker emailed Falken for the recommend PSI.
    Also max is a maximum. Not to exceed.
    You're overinflated.
    DrFunker and ChadsPride like this.
  19. Dec 9, 2016 at 7:28 AM
    Adventure4x4
    Adam
    San Antonio, TX
    Okay, yeah I wouldn't inflate to maximum. I never thought though that the recommended was that much lower than the max...interesting. Well now I know, thanks. I guess also I started caring about mpg; may as well give up on that haha
  20. Dec 9, 2016 at 8:02 AM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    Agree with Buddy here, should not be riding that rough with the overload removed too. I have Billys in the rear with the overload removed and its very smooth.
    PSI is set at 35 all around.
