Rear aal or spacer with air bags
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tigris99, May 3, 2021.
  1. May 3, 2021 at 10:32 AM
    Tigris99
    Tigris99 [OP] Well-Known Member
    St Louis
    2021 AG Trail edition
    OK not dropping coin for a full leaf pack. Got new eibachs on order for front to bring it up an 1.5"ish.
    I have ride rights in the back since I carry 4 kayaks, will be carrying camping gear and possibly 3 mtbs on the hitch rack all at the same time. Depends on if everything will fit in the bed. Otherwise will be towing my small trailer with the bikes in it along with coolers.
    Looking at AAL instead of 1" spacer. But only constant rear load is the bed rack which is about 100lbs.
    With bags deflated (for measuring purposes) is only about 0.5" higher than front. Measured at center of tire to bottom of flare.
    Was thinking single long add a leaf from wheelers instead of going 1" block. So around 1-1.5 lift in rear.
    Any reason NOT to go the AAL route. Be doing the work myself so not worried about that provided no unforseen problems as chasing parts will be a bit difficult once project is started.
    Thanks.
  2. May 3, 2021 at 10:38 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I would do one of the 3 leaf aal's instead. I rode in a truck with a single and it was much stiffer than I was hoping for.
    SunRunner and na8rboy like this.
  3. May 3, 2021 at 10:53 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    IMO 3 leaf AAL will be best. Really helps the rear end handling of a Tacoma. Spacer makes handling worse.
    Also, if the air bags are bolted on top and bottom, may need a spacer for the bags. Don't want to overextend them.
    na8rboy likes this.
  4. May 3, 2021 at 11:04 AM
    Tigris99
    St Louis
    Nope bags are on cradles. Did that on install as mild offroad does happen.
    Superdave1.0 likes this.
  5. May 3, 2021 at 11:04 AM
    Tigris99
    St Louis
    Was that single the long one that goes in the stock leaf pack, not under it?
  6. May 3, 2021 at 11:06 AM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    It was a single that goes under the stock springs. It had been on the truck for about 2 months and seemed way stiffer than my truck with the same shocks on it. I ended up going with a 3 leaf and it rides much better.
    If I was going to run a single rear spring I would do one of these. Supposedly they have the best ride for a single rear spring. https://archivegarage.com/explore-archive/ols/products/2005-tacoma-traveler-aal
  7. May 3, 2021 at 11:57 AM
    Tigris99
    St Louis
    That's basically what the wheelers is I'm looking at, long and goes up in the pack. Seems like a middle ground between progressive pack and the crappy under pack AAL.
  8. May 3, 2021 at 12:13 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I think all the aal’s go in essentially the same spot between the factory overload and the leaf springs.
  9. May 3, 2021 at 1:30 PM
    Tigris99
    St Louis
    OK that must be the whole progressive and remove OL thing I keep reading
  10. May 3, 2021 at 1:45 PM
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    Loving my deaver single AAL with 5100s. Its held the 1 inch lift with 400 pounds constantly in the bed for 5k miles now and rides like stock.
