Rear abs cable
Discussion in '3rd Gen. Tacomas (2016-2023)' started by grsabourin, Dec 6, 2015.
  1. Dec 6, 2015 at 12:56 PM
    grsabourin
    grsabourin [OP] Member
    Hi
    I have accidentally break a rear abs wire. I have the brake, abs and anti slip light on in the dash panel. I have repaired the connector an reconnect. The light are still on in the dash panel. Is it something to reset or my wire is still bad
    Thank you
  2. Dec 6, 2015 at 1:00 PM
    TMMIgirl
    TMMIgirl Well-Known Member
    Angela
    Haubstadt Indiana
    TRD off road DC SB
    Try unplugging the battery for ten minutes to reset the dash lights.
  3. Dec 6, 2015 at 1:10 PM
    grsabourin
    Is it something I can reset by the way of the odb2 connector
  4. Dec 6, 2015 at 1:57 PM
    TMMIgirl
    Angela
    Haubstadt Indiana
    TRD off road DC SB
    How did you make the repair?
  5. Dec 6, 2015 at 1:58 PM
    grsabourin
    Yes it is repaired and record reconnected
  6. Dec 6, 2015 at 2:01 PM
    TMMIgirl
    Angela
    Haubstadt Indiana
    TRD off road DC SB
    Do you have pictures?
    It could be wired wrong. If it's not you need to disconnect the battery for awhile to reset the computer.
  7. Dec 6, 2015 at 2:12 PM
    grsabourin
    Finally run few km and all is reseted
  8. Dec 6, 2015 at 2:18 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    This is the 3rd gen section. Do you have a 3rd gen?
  9. Dec 6, 2015 at 4:12 PM
    grsabourin
    Sorry I think mine a second generation
