Rear AC plug capabilities
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KBOX, Apr 15, 2018.
  1. Apr 15, 2018 at 5:36 AM
    KBOX
    KBOX [OP] In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    We are in the middle of a rather severe ice storm and I do expect the power to go out. If it does, what can I run off that rear outlet if I absolutely need to?
  2. Apr 15, 2018 at 6:15 AM
    Col4bin
    Col4bin Well-Known Member
    Maine
    2018 TRD OR Double Cab
    Following. Would be a nice resource to know what folks have successfully done
  3. Apr 15, 2018 at 6:17 AM
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Anything that requires 400W or less as that’s what the outlet is rated for.
    You can look at the back of nearly any electric appliance and you’ll see the Voltage requirements. IF.... you’re thinking a heater or anything like that forget it. They’re 1500W plus. As an example a coffee maker is ~1700W and 100 Watt light bulb is.... well it’s 100W. You get the idea.
    No fridge, no freezer, no heaters.
    400W is NOT much
    **** edit ****
    (Added some more info just in case)
    V*A=W
    So if your appliance lists a certain Amp requirement at 120 Volts you must multiple to get Watts.... again 400 is minimal. Count on keeping your phone charged to order Pizza and not much else.
  4. Apr 15, 2018 at 6:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    But doesn't the truck have to be running for the inverter to work/make the outlet hot?
  5. Apr 15, 2018 at 6:21 AM
    YOTA 4X4
    Yep unless you Mod it... in which case your battery sure won’t last long.
    Col4bin likes this.
  6. Apr 15, 2018 at 6:25 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I think a small generator would be better suited to the task. This little guy can at least keep your fridge running.
    RobP62, Dirty Harry and Tocamo like this.
  7. Apr 15, 2018 at 6:43 AM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Exactly. I used one of those 4 to 5 hours a day, 4 days a week all summer a few years back. They were labeled Chicago electric then I believe. It ticked all summer without an issue. The only maintenance I did was before I even used it I put a decent spark plug in.
    EatSleepTacos[QUOTED] likes this.
  8. Apr 15, 2018 at 6:48 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
  9. Apr 15, 2018 at 6:57 AM
    KBOX
    Jody
    Acton, Ontario
    Stock
    Ok, I guess there isn't much I can run off it. Was basically thinking the kettle and coffee maker but those need 1000 and 1500 watts.
  10. Apr 15, 2018 at 11:24 AM
    Clearwater Bill
    Billy
    Largo Florida
    Propane campstove for the basics. Used safely of course.
    Anker battery pack to recharge portable devices, but the truck would recharge it fine.
    Got bigger stuff, get a Honda generator. Very quiet, durable.
    Says the guy who worked for a power company a long time and lives in hurricane territory.
  11. Apr 15, 2018 at 11:47 AM
    YOTA 4X4
    -Yep. I have a 2000W Honda inverter Gen Set, though at $1000 dollars it’s not a good choice for power outages. But Top choice for camping. You can get a large generator to power your entire home for much much less.
    If you do want to power your home or other large devices off your truck there are 5K even 10k inverters that run off vehicles.
    Just be aware electricity is Math. Calculate what you need and choose appropriately. No guessing. Do the Math... calculate your requirements (well pumps are normally 220V) and buy the appropriate Gen Set...
  12. Apr 18, 2018 at 7:35 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Awww
  13. Apr 18, 2018 at 7:36 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    So adorable, right?
    Dirty Harry[QUOTED] likes this.
  14. Apr 18, 2018 at 7:45 AM
    Dirty Harry
    Andrew
    SW Florida
    He's just a little guy.
    Comb and EatSleepTacos[QUOTED] like this.
