rear add a leaf to fix tacoma lean?
Discussion in '1st Gen. Tacomas (1995-2004)' started by blakewhisenant, Mar 7, 2013.
  1. Mar 7, 2013 at 1:03 PM
    blakewhisenant
    blakewhisenant [OP] Well-Known Member
    Blake
    Oklahoma
    1995 Toyota Tacoma 4x4 V6
    lots to come...
    I just had a three inch spacer lift put on. Looks good. I also changed out the rear shocks.
    I now notice that the truck has a lean to it. "the taco lean"
    I an not wanting to add the 1/4" spacer since I have the 1.5" (3inch) spacers now. Its to much lift and stress on the front end.
    What if I added an add-a-leaf to only the right rear spring pack would this level the truck?
    other options? Besides fat girls...
    pinchenolan likes this.
  2. Mar 7, 2013 at 1:03 PM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    oh, I also added two inch spacers to the rear. (blocks)
  3. Mar 7, 2013 at 1:06 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I think would just result in Rake, and then you'd have lean to rear side that doesn't have a Add a leaf. When I put my 3 inch spacers in I put my add a leafs in and it lifted it about an inch more than the front.
  4. Mar 7, 2013 at 1:10 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I put on sway away 2.0 coilovers, wheelers 5 pack leafs, and a wheelers 1.5'' AAL to add to the leaf packs...and I still have a wicked taco lean....
    Trying to adjust the coilovers now to correct the lean
  5. Mar 7, 2013 at 1:16 PM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    I think that if I added the leaf pack to only one side it would have the same impact that the 10mm driver side spacer has?
    Right? Wrong?
  6. Mar 7, 2013 at 1:21 PM
    TacoMX
    Jonathan
    Deltona, Florida
    wrong...the taco lean is mostly attributed to the front suspension because thats where all the weight is (motor, trans)
    Adding an AAL to only one side will make the truck lean weird and ride strange.
  7. Mar 7, 2013 at 1:23 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    No, if you want to avoid a spacer, get what is called a trim packer, toytec has them.
  8. Mar 7, 2013 at 1:25 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Shit disregard this idea, only works on OME
  9. Mar 7, 2013 at 1:27 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Trim packer is for OME shocks. Other shocks you need to use 1/4 top plate spacers
    Edit nevermind you got it
  10. Mar 7, 2013 at 1:27 PM
    TacoMX
    Jonathan
    Deltona, Florida
    it might work with any shock as long as OME shocks have the same outer diameter as any other shock. The trim packer just goes under the lower spring perch
  11. Mar 7, 2013 at 3:00 PM
    02trdtako
    02trdtako Lurker
    scor
    02 TRD 4WD XtraCab
    Eibach coils, Bilstein 5100's set at "0", diff drop, AllPro Expo leafs, Bilstein 5125 rears, 265/75/16 BFG All Terrain KOs, 1.25 SpiderTrax wheel spacers, Ultra 8 OEM spec air filter, external auto trans cooler, SnugTop Camper, Yakima Racks, Yakima Fat Cat ski holders, Valley receiver, LineX bedliner, BAMF BPV relocate, OME exhaust relocate, "custom" carrier bearing drop, JVC deck, CravenSpeed stubby antenna, 35% tint all around.
    My last 2 Tacomas both had a .5" difference up front and a .25" difference in the back. If you strain your eyes you can tell the difference. Most people don't even notice. My opinion - It's a truck, let it be. If not, the ToyTec .25" spacer should do the trick.
  12. Mar 7, 2013 at 3:11 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    The tacoma lean can be attributed to the addition of: driver, fuel, battery weight.
    plus gravity and time ;)
    I compensated primarily...
    by having 1/2" more arch added to muh Dr. side custom spring pak.
    My front Adj. CO's are pre-loaded level (no compensation)
    I also compensated some by installing my hi-lift opposing in the bed.
    as well balancing out any other permanently stowed items in the bed.
    I think this helps the spring paks settle and maintain a more proper level over their consumable life.
    Compensation when using Adj. CO's up front,
    is little more then pre-loading the driver's side slightly more.
    For non adj. CO's... it's possible to install a spacer
    in the CO (internal to coil) to lift the drivers side some.
    ( ^ not a top load spacer )
    * shims in the coil pak are ok...
    shims external (at the top) change the length of the CO
    and mess with the suspension's geometry
    Leaf spring riser blocks are not a great addition,
    because they can stress the individual leafs in a pak...
    Axle wrap becomes exaggerated and more noticeable
    T
    hat wrap could cause one of those leafs to fracture.
    lose those and have some rear leaf paks built to your needs $ .02
    ^ it's just money :p
  13. Mar 8, 2013 at 8:39 AM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    I saw the toy tec spacer.
    @ tacodell - shims in the front?
  14. Mar 8, 2013 at 8:42 AM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    Like the Mr. Gasket kind?
  15. Mar 8, 2013 at 11:43 AM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    I called toytech and they said I should not stack the two spacers together.
    Recap - I have a set of top plate coil spacers (3inch). I have all new OEM parts. I am not a hardcore wheeler, just wanted a taller tacoma/zombie truck.
    Driver corner droops anout half an inch.
    Any more ideas?
  16. Mar 8, 2013 at 11:46 AM
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    stuff and more stuff
    Ditch the spacers and get some coilovers and an AAL. Dont waste your money like I did :banghead:
    If you have coilovers then you stack the 1/4 inch spacer like I did to fix the lean.
  17. Mar 8, 2013 at 11:51 AM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    the money is wasted. The ride is stiffer than before, but I like it.
    I am suprised some one has not made an adjustable coil spacer lift. Like the top of a coil over. If someone steels this idea please send me a set for free.
    I am going to buy a set of mr gasket spacers and zip tie them in...
    When I buy a new tacoma I will do it right. So untill someone wants to buy my truck for market price I am just going to keep it a second ride.
  18. Mar 8, 2013 at 11:53 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    If you want to go against common sense, you could just grab the 1/4 spacer and stick it on your strut, however I don't recommend it.
  19. Mar 8, 2013 at 12:09 PM
    blakewhisenant
    Blake
    Oklahoma
    lots to come...
    yeah I want it to be safe on the road.
  20. Mar 8, 2013 at 12:13 PM
    TacoMX
    Jonathan
    Deltona, Florida
    The 1/4 spacer isn't unsafe at all. As long as you are not doing any hardcore offroading and you are not bottoming your suspension all the time, a 1/4" spacer above the drivers side c/o assembly would be a fine choice to help combat the lean.
