Rear Axel Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Creole Knight, Aug 1, 2013.
  1. Aug 1, 2013 at 2:12 PM
    Creole Knight
    Creole Knight [OP] Man's got to know his limitations.
    Ulysses
    So. Cal
    05 Super White PreRunner
    gear shift knob and other things.
    Please give me your honest openion, I have a 2005 double cab PreRunner One owner. I bought it in 05 and only used it to go to work about 24 miles a day, the truck is babied. I decided to do a 6" lift using spindles and Icon ext travel up front and resi's on the back along with custom built Devar leaf packs to even it out. I have 285/70/17 Nitto Trails with XD Cranks, I also added 1.25" Bora wheel spacers on the back to match the front since the spindles pushed the front out some. About a month and a half ago I got the Road Force Blance done and found one of the wheel/tire would not balance but the shop did what they could to get it close, the service rep said it could be either the tire, the rim or the axel. OK I'm going to shorten this, I got the truck Smoged the other day and while they had it on the dyno I noticed the right passanger tire wobbleing pretty bad. I just bought a new rim and tire for a spare so I brought it to the shop and they put it on, same thing wobble. I could see it was the axel. I have kept this truck in Mall Crawler shape you could eat off the underside of this truck mind you I am an old retired dude with a kids truck I just like the Tacoma and how it looks. I have said this because I do not go wheeling, hell, I havent even gone over 500 hundered miles on one trip. Now my question, HOW THE HELL DD MY AXEL GET ENT. NO ONE ELSE DRVES THE TRCK CAN'T FND ANY MARKS THAT T WAS HT ON ETHER SDE. Please tell me what you think. I'm beginning to believe there is some foule play going on between the original shop that installed the lift.
  2. Aug 1, 2013 at 6:20 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I seriously doubt that you have a bent axle from what you have posted.
    " I also added 1.25" Bora wheel spacers on the back"
    I would remove the spacers and then recheck it. ( I think the spacers are the issue and not the axle).
  3. Aug 1, 2013 at 6:42 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    agreed 100% are the Boras hub/centric?
  4. Aug 1, 2013 at 7:46 PM
    Creole Knight
    Ulysses
    So. Cal
    Yes the Bora's are hubcentric. I watched the axel turn with the wheel on with the wheel off, and with the brake drum off and it wobbled. I saw it was my axel. I just don't have a clue how it got bent. I did not run over anything I did not hit anything. The only reason I posted here was I did not want to put anyone on blast. It just damn odd to me.
  5. Aug 1, 2013 at 7:52 PM
    92dlxman
    Kevin
    Visalia, CA
    that is really weird. people fly these trucks without bending axles, I don't understand
  6. Aug 1, 2013 at 11:36 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    You have to check the run out on the hub not the flange of the axle shaft.
  7. Aug 2, 2013 at 7:17 AM
    Creole Knight
    Ulysses
    So. Cal
    Fella's I don't mind being corrected but do you have to be so hurtfull I am just looking for help with my Tacoma. But thank's anyway.
  8. Aug 2, 2013 at 7:29 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    i think the correct term would be come on not comon... the mans axle shaft is bent and or bearing is bad. cant anyone tell him that or how to use a dial indicator or borrow one to check it?? this site is about helping others with similar vehicles is it not? or is it all about the me's of this place who waste bandwidth for nothing with stupid posts? if im wrong here then correct me...have a nice day:)
  9. Aug 2, 2013 at 8:25 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    What's the heaviest load you've carried in the truck, and did you do the installation yourself or have a shop install stuff?
  10. Aug 2, 2013 at 9:13 AM
    Creole Knight
    Ulysses
    So. Cal
    I have not carried anything in this truck. I had a shop do the installation I watched as they installed the equipment. The only conclusion I can come to is that someone hit it without leaving any marks on the fender or marks on the tire that I did not notice at the time. The rear tires stick out away from the fender's about a inch and a quarter so it's possible they hit the tire and not the rim but that's a long shot. Just weird. I will do as fixer5000 said and use a dial indicator maybe that will give me an idea. Thank's
  11. Aug 2, 2013 at 9:27 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I would think that if someone hit your truck hard enough to bend an axle, that the exterior of the truck or tire would have significant damage. Do you hear any noise when the tire is spinning like bad bearing noises or anything?
  12. Aug 2, 2013 at 10:13 AM
    Creole Knight
    Ulysses
    So. Cal
    No noise and I would not have even noticed it until they put it on the dyno and I saw how the tire had a wobble on the passanger rear side. I think it started when I took the truck in to be road force balanced and the service advisor told me he could not balance one of the tires but got it as close as he could and placed it on the rear passanger side. I informed him at that time the truck had not been used for anything else than transportation. He told me it was either the wheel, tire or axle. I had them put on a new wheel and tire I had for a spare and the same thing happened, I watched as the spacer was turning and with the brake drum on and off I watched the hub wobble. I don't know, unless this guy during the first road force balance did something to the right side rear axle I just don't know what to believe after all I was not in the truck during the test drive after service. This seems like a good shop I have had them do regular scheduled Maint. but who knows and you are right I should have some kind of shaking or noise but I do not. It's just damn weird.
  13. Aug 2, 2013 at 10:38 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    I'm sorry to hear about that.
    Only advice I can give you, if it were me I'd start taking off parts and find the problem. If it is truly a bent axle or a really cocked bearing I too would be suspicious. If you trust the shop, why not come to them with the problem and see what they say? If the shop was questionable, I'd wonder if the truck slid off of a lift or stand. Look really hard underneath for any other damage. I watched a few yahoos try to lift their f150 with a forklift when the damn thing slipped and shoved a fork through a wheel well.
    Oh, and 43 here. It's not a kid's truck. It's that we like cool trucks.
  14. Aug 2, 2013 at 11:00 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is truly weird. I would check at the axle hub with a dial indicator also. Something obviously happened to the truck that you do not know about. It didn't bend from just driving it.
  15. Aug 2, 2013 at 6:53 PM
    Creole Knight
    Ulysses
    So. Cal
    Thank's guys I will check it out and see what could have done this. I appreciate all the help and I am thankful that I can come to this fourm for help.
  16. Aug 5, 2013 at 8:21 AM
    Creole Knight
    Ulysses
    So. Cal
    Got one more question fella's, I need to change out my axle it is bent and I still don't know how it happend although I have an idea, do I also need to chanage the bearing.
  17. Aug 5, 2013 at 8:22 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    What bearing?
  18. Aug 5, 2013 at 8:23 AM
    mjp2
    NJ
    If you're taking stuff apart anyway it's worth the extra step to replace the bearing and seal while you're at it. Shouldn't be necessary unless you have a leak, but might as well since you're already in there.
  19. Aug 5, 2013 at 8:25 AM
    Creole Knight
    Ulysses
    So. Cal
    10-4 thank you mjp2.
  20. Aug 5, 2013 at 8:29 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You changing the axle or just the shaft?
