Rear axle bearing replaced
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GimmeTacoma, Sep 24, 2022.
  1. Sep 26, 2022 at 6:57 AM
    GimmeTacoma
    GimmeTacoma [OP] I LOVE the tacos
    Jacob
    2009 Prerunner double cab AT black
    not much tbh
    “Well having them labeled from the get go would have been helpful. Part of the problem with not having the vehicle here. Where did you get the bearings?”
    Like it’s my job to tell them how to do their job they agreed to do. Would have been fine if they just put them together the exact way they were done before…
    Taco 422 and andrewtheadventurer like this.
  2. Sep 26, 2022 at 7:05 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    It sounds like they are just making up excuses for their wrong doing. That's some bad customer service there.
    Ricardo13x likes this.
  3. Sep 26, 2022 at 7:06 AM
    GimmeTacoma
    Jacob
    not much tbh
    Yeah, I’m gonna send them pics and maybe even just take it to them and explain it in person cause that would be easier
  4. Sep 26, 2022 at 6:11 PM
    daluvian
    daluvian Well-Known Member
    San Diego
    2005 Tacoma
    Long travel
    The sensor hole doesn’t need to be drilled just one tapped hole for the sensor to be flipped. There is absolutely no downside to doing this very simple 5min job per side no need to fill or do anything with the open thread it doesn’t go all the way threw. You would be saving perfectly good bearings, it would be a waste to have them put new bearings I know it sounds corny but I hate seeing parts wasted. As poster saying he wants it done right, I don’t see this ever causing any issue. Its a mistake anyone could have done no reason to make the shop eat 300$ for something easily fixed, but they should be the ones to drill and tap if you don’t have the tools, and ask for some money back for the inconvenience and gas. Maybe you should offer this solution to the shop and go from there
  5. Sep 26, 2022 at 6:58 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    I would go this route just to avoid the headache. It sucks when you pay with hard earn money and the counterparts doesn’t follow through and try to blame the customer.
    daluvian[QUOTED] likes this.
  6. Sep 26, 2022 at 9:32 PM
    GimmeTacoma
    Jacob
    not much tbh
    they're still determined that it wasn't their fault, but they did reluctantly say they were gonna order replacement bearings and that they'd press them for me. I'd still have to do the work again, but ¯\_(ツ)_/¯ . Maybe I'll see if they can like give me a refund or alignment and tire balancing or something. we'll see
  7. Sep 26, 2022 at 9:40 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Guess I never looked that closely. I know when I did my bearings, I did them just as I do rear drum brakes....one side at a time to verify it goes in the same way it came out.
    That right there is admission of guilt, so you're making progress. Keep working them until you get what was initially promised, a set of rear wheel bearings installed CORRECTLY.
  8. Sep 27, 2022 at 9:43 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    It's been awhile since I did my rear bearing, but I recall the connector to the sensor was "directional," such that if you flip the sensor, the connector would be facing inward toward the backing plate. Would there be enough clearance in such a case for the connector/harness connection?
  9. Oct 14, 2022 at 9:01 AM
    GimmeTacoma
    Jacob
    not much tbh
    Yeah, that’s correct there’s no turning it and installing it facing outward. I had the shop get me new bearings and press them. Got everything installed again yesterday and everything is working!! Thanks all
  10. Oct 14, 2022 at 9:14 AM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Make sure it is OEM. They could be ordering dorman to save the cost of the fuck up.
    Honestly, I would get your money back and go somewhere else.
  11. Mar 11, 2023 at 9:17 AM
    Spif
    Spif vehicle: 2014 Taco 4x4 double cab
    2014 Taco 4x4 double cab - 125k miles
    Does this actually work in practice?
    Does the speed sensor not know that it’s reading the magstrip of a wrong side bearing? My concern is, would the speed sensor see a wrong-side magstrip and think it is rolling in the reverse direction?
  12. Mar 11, 2023 at 11:18 AM
    Bishop84
    Bishop84 Well-Known Member
    Yes, the sensors and magnetic rings are just flat tabs.
    I’ve seen it work twice, faaaaaar from ideal.
    I triple check any bearing set I get because of this simple error
  13. Mar 12, 2023 at 11:09 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
  14. Mar 16, 2023 at 9:07 PM
    wilson23
    wilson23 Well-Known Member
    This works, ive done it and run it for years no problem
  15. Mar 17, 2023 at 4:11 AM
    #35
    Spif
    Anyone know what all those acronyms mean? The systems affected by the speed sensor readings?
    ABS = antilock brakes
    TRAC = traction control?
    LSD = limited slip differential
    others = ?
  16. Mar 17, 2023 at 5:43 AM
    #36
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    VSC is traction control. Your manual should explain them
  17. Mar 17, 2023 at 9:25 AM
    #37
    6 gearT444E
    Deep South
    Herculiner Hootus
    See attached
    Spif[QUOTED] likes this.
