Rear axle bearings and seal questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dward, Dec 31, 2021.
  1. Dec 31, 2021 at 3:24 PM
    dward
    dward [OP] Member
    Dennis
    2005 Tacom 4x4 4 door
    I have been searching and reading various threads, watched a couple of youtube DIY videos.
    I spotted grease on the surface of the wheel, and pulled the drum off the left rear today to verify axle seal is leaking. Looks like it just started leaking. Truck has about 110K miles, with no off road.
    If I decide to replace the bearing, should I get the hub and bearing assembly?
    I assume I could get just the bearings, but that would be more work for machine shop?
    Needless to say, I'm a little confused about what is needed at this point.
    I wanted to tear down myself and take axle to a machine shop, but want to make sure I have the correct parts.
    Any input appreciated.
    Thanks
  2. Dec 31, 2021 at 3:33 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Yes I would get the hub/bearing assembly
    Easier
  3. Dec 31, 2021 at 3:38 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Check the rear brakes for oil contamination. May just be worth it to service the brakes (anyway).
  4. Dec 31, 2021 at 3:47 PM
    dward
    dward [OP] Member
    Dennis
    Indeed, I purchased rear brake shoes about 2 years ago and when I went to install, decided it didn't need them yet. I guess it does now since one side is lubed up pretty good.
  5. Dec 31, 2021 at 3:57 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    wi_taco, Larzzzz and 6 gearT444E like this.
  6. Dec 31, 2021 at 4:06 PM
    dward
    dward [OP] Member
    Dennis
    Thanks guys, got some reading to do now....appreciate the info.
  7. Dec 31, 2021 at 4:10 PM
    Bishop84
    Bishop84 Well-Known Member
    Yup, new bearing, bearing housing, retainer, axle seal, oring, snap ring, retainer, 4 studs, spacer washer, all needed.
    Definitely just remove it and give it to a driveline shop.
    TnShooter likes this.
  8. Dec 31, 2021 at 5:24 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Do both sides and change the diff fluid.
    Get a new diff vent or do the remote mod to let it always vent - many posts on that as a clogged vent can cause the leak.
    Grossomotto likes this.
  9. Jan 1, 2022 at 10:41 AM
    dward
    dward [OP] Member
    Dennis
    How do I know beforehand if I have an ABS ring on the axle?
  10. Jan 1, 2022 at 12:13 PM
    muddog321
    FL
    It's part of the hub assembly and sensor mounts into it. Find the wires and connector.
  11. Jan 1, 2022 at 10:44 PM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I did this a few months ago. Unfortunately. You need to buy a bearing assembly- there's no other choice. I bought Timken from Rock Auto and it was a made in USA Koyo unit identical to OE Toyota part.
  12. Jan 10, 2022 at 8:21 PM
    dward
    dward [OP] Member
    Dennis
    Finished up the driver's side today. I replaced the brake shoes while I was there, but still didn't really need it after 110k miles. I don't know why I didn't go ahead and order parts for the passenger side at the same time, but went ahead and ordered everything today.
    Hopefully, by the end of the week will have the passenger side done as well.
    The hardest part of this repair (for me) was getting the brake shoes back on. I did take the bearing and axle to a machine shop.
    Glad I had ordered a new retainer as the old one was a bit chewed up from the oil seal spring that had worked loose.
    Thanks for all the invaluable help guys, much appreciated.
    whatstcp and 6 gearT444E like this.
