Rear axle bearings?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crashnrondo, May 4, 2025.
  1. May 4, 2025 at 7:03 AM
    crashnrondo
    crashnrondo [OP] Well-Known Member
    Ron
    Wisconsin
    2021 DCSB Limited
    In the last week I've got a hum/buzz noise coming from the rear, that's most noticeable above 60mph. I can't change the noise by swerving and I can't hear anything grinding when jacking up the truck up while spinning the tires by hand. I'm just over 77,000 miles with new tires 5000 miles ago, I just rotated the tires and the noise didn't change or move. The rear diff is up to level and has been changed 5 times already. This is my DD so no harsh off-roading, just forest roads to get to hunting and fishing spots. I do have the diff howl/whine and that's still there, the new noise is about the same level in the cab but it's constant at highway speeds. I'm leaving for a short vacation Tuesday that will be about 600 miles round trip, do I trust it or take the wife's car but then we can't bring the bikes?
  2. May 4, 2025 at 8:55 AM
    Meclizine
    Meclizine Well-Known Member
    CA
    '18 DCLB OR
    Any play in the carrier bearing?
  3. May 4, 2025 at 10:41 AM
    crashnrondo
    Ron
    Wisconsin
    2021 DCSB Limited
    Good thought, but the carrier bearing feels just fine.
  4. May 4, 2025 at 10:44 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    It’s probably just those new tires.
  5. May 4, 2025 at 1:18 PM
    Meclizine
    CA
    '18 DCLB OR
    Dang. Worth a try!
    Yeah, you're probably right.
    @crashnrondo, are these new tires the exact same as the last set or a different make, model, or size? How are your shocks? I think dying shocks can let tires cup and that can cause noise at speed.
  6. May 4, 2025 at 1:35 PM
    crashnrondo
    Ron
    Wisconsin
    2021 DCSB Limited
    I'm 99% sure the noise isn't the tires, all 4 are nice and smooth with no cupping or feathering. My old tires wore very evenly and looked good when I pulled them off, unfortunately I sold them so I can't try them. Shocks are new 4600's last fall, tires and rims are new take offs from a 2023 Sport with less than 50 miles, so not the same as my old tires/rims. I've never had a bearing go bad except a front one on my wife's Rav4, that I could change the pitch by swerving. Not sure with the rear solid axle works the same way.
