Rear Axle Blown. Cost of repair?
Discussion in 'Technical Chat' started by Mr. Biscuits, Feb 2, 2013.
  1. Feb 8, 2013 at 5:31 PM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    Wrong, if oil is leaking through the seal it has washed the grease out of the bearings and they require replacement.
    Glad the op got it fixed without the major expense he was expecting.
  2. Feb 8, 2013 at 6:00 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    :woot:
  3. Feb 8, 2013 at 6:02 PM
    jandrews
    '09 FourDubDee TRD OR
    Depends how long the problem has been going on. Rear axle bearings are enough of a PITA i'm only going to bother replacing them if they tell me I need to. I'm not "fixing" something when there are no signs or symptoms.
  4. Feb 13, 2013 at 8:25 PM
    Mr. Biscuits
    Mr. Biscuits [OP] gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    Don't mean to revive the dead thread, but the squealing is unaffected and continues to haunt me. And idea what it could be?
  5. Feb 14, 2013 at 5:12 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Is the noise road speed dependent? Or engine RPM dependent?
  6. Feb 14, 2013 at 8:43 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Yeah they are! :p
  7. Feb 16, 2013 at 7:20 PM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    Update. The squeal turned out to be dry u joints. They greased then no charge but it hasn't exactly remedied the situation completely. It doesn't squeal, but I can tell it's still down there just waiting. Biding its time.
    While the truck was on the lift I gave her a good look see, didn't know when I'd get the chance to do it again and gave the driveshaft a good push. It has a lot of play in the carrier bearing. Is that normal? What would the symptoms of a loose carrier bearing?
  8. Feb 16, 2013 at 7:34 PM
    jandrews
    Carrier bearing is essentially suspended inside a stiff rubber donut. Acts as a bushing to absorb vibration. First signs it's going bad tend to be vibration and/or noise. Or if it's falling the fuck out of the mount because the rubber has rotted out.
    A good inch or so of slop is normal.
  9. Feb 16, 2013 at 7:36 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    replace the u-joints, they are cheap. if problem ensues, spend the 150+ on a carrier bearing.
  10. Feb 17, 2013 at 5:51 PM
    96 tacomaPtown
    96 tacomaPtown Well-Known Member
    Bryan
    Oregon
    96 ext cab 4x4 taco
    3 inch spacer lift,pro comp addaleaf, 1 inch diff drop kyb shock/struts, Lc engineering header, stock muffler, hollowed cat, 2 1/4 exhaust, o2simulator , 31 10.50 15 wranglers on stock. Hella 500 headlamps, bug gaurd, vent visors, bed caps, bed liner, Volant cai intake.
    i replaced one outer seal recently and slapped everything back together to see if leak would be fixed. but what it took was replacing both outer seals and inner seals including having the bearings replaced and shoes and wheel cylinders, i did everyhting but press old bearing off and on, to get to inner seals you have to take old bearings off and requires someone with smithing experience or tools. you dont have to replace both sides i did to take care of whole rear axle so I knew it was all taken care of.but you have to replace shoes cause old ones will get soaked with oil and break down your shoes
  11. Feb 17, 2013 at 8:59 PM
    BamaToy1997
    Bill
    Navarre, FL
    If the universals were squealing, then they were dry, and wearing. It would be best to go ahead and replace them now, while they are just noisy, instead of putting them off and risk breakage.
