Rear axle centered to box wheel wells ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by The OR LB 16, Aug 2, 2016.
  1. Aug 2, 2016 at 6:46 PM
    The OR LB 16
    The OR LB 16 [OP] Well-Known Member
    Tom
    Tacoma 2016 TDR Off road LB
    I was at the dealer for the TSB flash and while there I asked about another problem
    My drivers side front and rear sits 3/4 inches lower than my passengers side empty with 1/2 tank of gas. And my rear drivers tire sits inside the wheel well by 1/4 inch and the passenger tire sits outside the wheel well by 1/4 inch. I have read about the "Taco lean " and am not worried about that too much but the centering of the wheels is what bothers me .
    The service manager and the tech measured 2 new 2016 on the lot which happened to both be the same TRD OR LB truck I have . They said they were off the same and even more than mine on both measurements. I did not and do not feel anything wrong while driving it . I would not even have known about it if not for putting on my sumo springs. I was checking it out to see what the difference was going to be before and after the spring install .
    Anyone else have this problem ?
    Blueboy likes this.
  2. Aug 3, 2016 at 6:35 AM
    cowboyup_again
    cowboyup_again Well-Known Member
    Interesting :popcorn:
  3. Aug 3, 2016 at 6:41 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Bed is probably misaligned with the frame. You or the dealer can loosen the 6 torx bolts in the bed and attempt to shift the bed over a bit.
    The OR LB 16[OP] likes this.
