Rear Axle damage?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kamille.bidan, Mar 20, 2019.
  1. Mar 20, 2019 at 11:07 PM
    Kamille.bidan
    Kamille.bidan [OP] Well-Known Member
    2017 Blue TRD OR MT
    I think I messed up big time.....
    Some guy in a Civic pulled into the street from a parking lot, nearly hit me in the process, then he just sat idle in the middle of the road, blocked the road and caused a small traffic jam.
    As I drove around him, I got really pissed off and Rev'd/dumped the clutch to skirt in 1st and then in then screeched in 2nd. I mean-mugged the guy the whole time. After I did this, I felt like I was driving on a really bumpy road, but the pavement was smooth and flat. I didn't hear any loud bangs or grinds after I screeched out in 2nd gear.
    The vibrations seemed to come from the rear end of my truck. I think I may have damaged my rear axle. I feel really f'ng stupid now.
    I took a look at the rear-end, and I noticed that my Differential has fluid seepage. Maybe, I can tie this all together and get this repaired under warranty?
    AxisCab likes this.
  2. Mar 21, 2019 at 1:27 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    A very expensive mess . Hope you get it covered. Bent axle ?
  3. Mar 21, 2019 at 1:37 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Check for a flat spot on one of the rear tires. The fluid seepage could be unrelated.
  4. Mar 21, 2019 at 2:09 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
  5. Mar 21, 2019 at 4:14 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    I would guess the rear leaf spring u-bolts were not tight enough and let the axle slip out of alignment slightly.
  6. Mar 21, 2019 at 4:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    If the internals of the rear assembly are damaged after one on pavement clutch dump/power shift, they are lame.
    But seepage is worth noting to your dealer at your next 'free' service stop. There was a warranty repair for a pile of those.
  7. Mar 21, 2019 at 4:40 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Tire damage. The seepage is almost certainly unrelated. It would be almost impossible to start your diff weeping because you did a burn out. These trucks are a lot tougher than that.
    michael roberts, Freegolf and tacotoe like this.
  8. Mar 21, 2019 at 5:35 AM
    Burro09
    Burro09 Well-Known Member
    Miami, FL
    2017 Tacoma TRD Pro Cement MT
    What you felt is how much leaf springs suck for a street truck.
    I also dumped my clutch once in 1st and lit the rear up from a standstill. (Traction control off). Never again will I do that. It felt like I was on a bucking bronco with all the axle wrap.
    On a side note, my diff has had seepage on both sides since before this incident. It also has howled since new.....Off to the dealer....
  9. Mar 21, 2019 at 5:39 AM
    Clearwater Bill
    Billy
    Largo Florida
    What you felt is how much Tacoma leaf springs suck for most things
    FTFY.
  10. Mar 21, 2019 at 5:40 AM
    dre5491
    dre5491 Well-Known Member
    Devin
    Cincinnati
    2019 MGM TRD Off Road
    Do seat covers count?
    If dumping the clutch once ruined your rear axle it isn't your fault. Yes it is a form of Abuse but, realistically if this is not something you commonly do it shouldn't be a problem. If you did it all of the time it'd be another story. I'd take it back to the dealer and do a warranty claim, I wouldn't even mention how it happened. Something was already loose/screwed up in the first place you dumping the clutch just made it worse. And as several people on here already mentioned, the leaf springs on these trucks suck so that is your likely culprit.
    wilcam47 and xxTacocaTxx like this.
  11. Mar 21, 2019 at 6:50 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Most likely, only damage is to ego and reputation for such a maneuver.
    Insternets searches "wheel hop" lives and learns, next step drives with a derby style hat, huge coffee, and drives reeeaallllll slow.
    tacotoe and TireFire like this.
  12. Mar 21, 2019 at 7:11 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Let me get this straight...
    You want to try to get something fixed your stupidity caused on my dime?
    No fucking way.
    You would gain short term. Unfortunately, we all lose in the long run because Toyota and dealerships will simply hike their prices to cover stupidity and then we all lose.
  13. Mar 21, 2019 at 9:07 AM
    Kamille.bidan
    2017 Blue TRD OR MT
    I took it to the shop this morning. It was vibrating on the way there. Thankfully, one of the cool guys that I am familiar with is handling the case.
    I am always cool with people, so I nearly always get hooked-up.
    It's all free service for now. I don't know if it will be free if they find something.
    bulalo and tacotoe like this.
  14. Mar 21, 2019 at 9:17 AM
    Burro09
    Miami, FL
    If he had drag slicks on the truck and was purposely trying to break it sure. But honestly if these trucks cant handle simple drop of the clutch, then the drivetrain is JUNK. Never have I had a stock vehicle where this caused any issues. Heck, these things dont even have an LSD. Its not like you do it every day all day. Let toyota fix their junk if bad quality is the cause of damage from a simple clutch sidestep.
    wilcam47, xxTacocaTxx and dre5491 like this.
  15. Mar 21, 2019 at 9:22 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You nor I have no clue what he did. There are two sides to every story man. Read the other thread on a broke diff.
  16. Mar 21, 2019 at 9:23 AM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Yeah, like someone mentioned, one episode really shouldn't hurt it.
    I have flogged my truck a few times and it never hurt anything.
  17. Mar 21, 2019 at 9:27 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You sound like one of those people that yells at cops saying "I'M A TAXPAYER SO I PAY YOUR SALARY SO I'M YOUR BOSS. YOU HAVE TO LISTEN TO ME."
  18. Mar 21, 2019 at 9:32 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    If a clutch dump is all it takes to bend an axle in a Toyota these days, then these trucks have no right to call themselves trucks let alone "offroad" machines. I sure hope that isn't the case.
  19. Mar 21, 2019 at 9:32 AM
    Kamille.bidan
    2017 Blue TRD OR MT
    I have solely owned Toyota vehicles for nearly 20 years straight. This is my third Toyota.
    I have done a lot of dumb things before especially in my MR2 when I was 19. This is the first time I have ever had to take a Toyota to the shop because I thought something was broken.
    I hauled a 2-ton palette of frozen turkeys on my second Gen. The tires rubbed the wheel well, and I still drove it for 10 miles. The truck went on for another 7 years after that with no issues. I missed that foolproof build quality, but I don't think any manufacturer makes vehicles like that anymore.
    tcjacado and AxisCab like this.
  20. Mar 21, 2019 at 9:33 AM
    96carboard
    96carboard Well-Known Member
    So, somebody who doesn't know how to drive turns onto the road, almost gets into a crash immediately, shits himself, panics, and stops to prevent doing anything else that might get him killed, and you blow your lid, freak out, and wreck your truck.
    Did I get that right?
    As if he wasn't already freaked out enough already.
    Or maybe driver was having a heart attack.
    Or maybe something in his steering or brakes failed.
    Sometimes stuff happens by nobody's intention. You gotta chill a bit, what happened didn't happen just to piss you off.
    TireFire and AxisCab like this.
