Rear axle help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by yotaco03, Jul 25, 2016.
  1. Jul 25, 2016 at 4:58 AM
    yotaco03
    yotaco03 [OP] Active Member
    Maine
    03 tacoma TRD SR5 V6
    bone stock
    My truck was making some horrible sounds from the rear that I figured to be the rear wheel bearings. So after looking up a few "how to" vids i decided this job was not for me, given i dont own a press and had a busy weekend ahead of me already. So i called my local mechanic who has done nothing for me other than yearly inspections. He assured me he could do the job. This was last Thursday mind you. He calls me last night and told me he has some bad news.... He said he cant get the axle back in.o_O he said it came out slick as shit but he cant get it back in. So ive been on the net all morning and cant find anything similar. What could be causing this?? Im hoping its just something dumb. So what im hoping to get from you guys is a list of things to try and or check for that could be the issue. Thanks!
    spudley likes this.
  2. Jul 25, 2016 at 5:59 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    What was the problem...the bearing? Why can't he get the axle "back in"?
  3. Jul 25, 2016 at 6:27 AM
    yotaco03
    Maine
    bone stock
    yes he agrees the bearing was bad and got the new one in but called me last night with "bad news". He says he cant the the axle back in. he says its as if the shaft has "swelled" or something. Hes stumped.. and not sure where to go from here. he told me it came out just fine.
  4. Jul 25, 2016 at 6:33 AM
    spudley
    spudley Member
    spud
    central NY
    SR5
  5. Jul 25, 2016 at 6:40 AM
    spudley
    spudley Member
    spud
    central NY
    SR5
    I had the same problem! simple fix as much as I hate to say it you have to take the drive shafts back to a Toyota dealer for they have a special press! noting that if the bearings are not pressed back to the specified length on the shaft the seals will leak!
  6. Jul 25, 2016 at 6:50 AM
    yotaco03
    Maine
    bone stock
    That sounds like another potential problem to me. he cant even get the shaft back into the pumpkin! how can this be?
  7. Jul 25, 2016 at 7:23 AM
    spudley
    spudley Member
    spud
    central NY
    SR5
    maybe the noise was the spider gear ? have him pull the 3rd member out and inspect the gears?
  8. Jul 25, 2016 at 7:26 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Sounds like a idiot. All you have to do is rotate the pinion some as you jiggle the axle in.
    wilcam47 likes this.
  9. Jul 25, 2016 at 8:03 AM
    yotaco03
    Maine
    bone stock
    Ill look into that when i go over later.
    I hope this is all it is... something simple... Ill be going over once he calls me.
  10. Jul 25, 2016 at 8:24 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    You kinda gota lift the axle up a bit to. But nothing hard to do...
  11. Jul 25, 2016 at 9:19 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    prob doesnt know what he's doing...
  12. Jul 31, 2016 at 2:44 PM
    APACHETECH
    APACHETECH Well-Known Member
    central pennsylvania
    2013 MGM DCSB OR
    Trd Baja lift Wheelers Aal SCS Ray 10 16x8s Cooper AT3 4S 265/75/16 Trd shift knob Weather tech front and back Heated seats Auto start Immryo mirror mod Mods to install : 4x4 lighted switch Speakers/components/sub and box from Mr. Marv Redline hood struts One piece engine splash gaurds Wish list/looking for : Matching cap Light bar/pods Seat covers Roof rack Step bar Skid plates
    I had same prob recently. The mechanic was trying to get bearimgs out and he hit the end of axle. After inspecting it closely I could see the end mushroomed a bit on one side. We had to grind that side down a bit and file out the grooves. It went right in.
  13. Jul 31, 2016 at 3:54 PM
    devinzz1
    devin
    2023 aclb trd or mt
    he managed to mushroom out the end of a hard ass axle???
  14. Jul 31, 2016 at 5:07 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Your 'mechanic' may have used the 'shade tree' method if he didn't have a press.
    The following image has been 'borrowed' from 4x4wire.com
  15. Jul 31, 2016 at 5:18 PM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    The previous owner of my Tacoma pressed bearings/retainer ring on too far or not far enou, anyways 2 new seals and they still leaked. $1500 later I no longer have leaking gear oil into my drums.......
  16. Jul 31, 2016 at 6:14 PM
    APACHETECH
    2013 MGM DCSB OR
    I guess mushroomed was an exaggeration. Lol. But it was hit hard on one side. I just changed my rear fluid twice today 50 miles between each change and the fluid is loaded with metal. Tons of little bits and a few big ones on magnet. Fluid is very dark already. Guess I should have taken it to dealer first time. I think its about to get real expensive. Hope you get yours figured out.
