rear axle leaks
Discussion in 'New Members' started by miketaco822, Sep 30, 2010.
  1. Sep 30, 2010 at 11:54 AM
    miketaco822
    miketaco822 [OP] Member
    migel
    oakley ca
    Yota runner
    so i have my tacoma for about maybe a year now got it around
    100thousand mile an i found the rear wheel leaking both side is
    this comin? i read a few forum on here in need of help
    i replace seal closer to the wheel still leaks
  2. Sep 30, 2010 at 12:01 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  3. Sep 30, 2010 at 1:08 PM
    miketaco822
    migel
    oakley ca
    Yota runner
    really my truck has about 135000 mile i recently replace just the seal that is
    like 6 bucks it the one on the drive shaft colser too the wheel you may think its a seal
    where my bearing is
  4. Sep 30, 2010 at 1:16 PM
    Got Taco?
    Got Taco? 1st Gen Taco
    North & West of Baja California also Arizona
    98 PreRunner, 05 SR5 4Runner, 06 D-Cab Sport
    1998 Taco: RevTek F/R lift ProComp shocks JBA cat back MagnaFlow cat cross drilled/slotted rotors K&N CAI Redline hood struts Flex-A-Lite dual radiator fan Galaxy DX979 (barefoot), Wilson 1000 (thru-roof). 2012 - Finally "Bro-Lean" status since springs have negative arch. =( 2005 4Runner: sold May 2013 2006 D-Cab Sport: (purchased new, paid off in 18 months, sold March 2010 for 2nd house) Current vehicles as of 2018: 1971 - Honda CT70 1997 - Lexus SC300 1998 - Taco (listed above) 2001 - Lexus GS430 2001 - Lexus IS300 2002 - Lexus SC430 2002 - Lexus LS 430 Ultra Luxury 2003 - Lexus GS430
    Bearing may be worn causing too much play in return it damaged the seal. "IF" the bearing is shot, it needs to be pressed in order to be replaced.
  5. Sep 30, 2010 at 1:40 PM
    miketaco822
    migel
    oakley ca
    Yota runner
    ya i also think it has somthing with the bearing also i have so much like grease an oil caked up under my rear fender an that aint a common thing at all
