Rear axle locking up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtav2002, Jun 27, 2010.
  1. Jun 27, 2010 at 5:14 PM
    jtav2002
    jtav2002 [OP] Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    So yesterday, I was pulling my boat out of the water, the ramp had a lot of wet sand that had accumulated all morning and my rear tires spun when I tried to pull up the ramp, so I put it in 4wd once I was up the ramp, put it back in 2wd. All was fine, later when I got around to unhooking the trailer to head out somewhere, the truck wouldn't move. Made sure I wasn't being stupid and still had the e-brake on, which it wasn't. I put it in 4wd again, and the front wheels moved the truck but I noticed both back wheels wouldn't spin and were just dragging in the grass as the front wheels pulled the truck. Quickly stopped, when I put it back in 2wd, I heard a loud clunk in the back, and the rear wheels moved fine then. And everything has seemed fine since. Any idea what the issue was? Haven't had that happen before in the year I had the truck.
  2. Jun 27, 2010 at 5:31 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    I would keep switching 4hi and 2hi to see if i will happen again and if not you are good to go.
  3. Jun 27, 2010 at 5:33 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    do you have the rear diff breather mod done?
    also, did the rear axle get submerged while pulling your boat out
    this sounds like you got water in you rear diff and destroyed/wrecked it...
  4. Jun 27, 2010 at 5:38 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    ^Possible, also e-brakes do stick once in a while. But his theory sounds better.
  5. Jun 27, 2010 at 5:45 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    change your rear diff fluid... before you do anything else.
  6. Jun 27, 2010 at 5:45 PM
    DWreck
    Derek
    Las Vegas, NV
    X2, check wheel bearings also
  7. Jun 27, 2010 at 6:07 PM
    jtav2002
    Josh
    Reading, PA
    No rear diff breather mod. And no the axle didn't get submerged. An inch high on the rear tires is the most I let the water touch the truck when I'm putting the boat in or out.
  8. Jun 27, 2010 at 6:10 PM
    DWreck
    Derek
    Las Vegas, NV
    Then e-brake may have stuck, or brakes in general if they were hot and rapidly cooled when submerged
  9. Jun 27, 2010 at 6:15 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    I would still change out the differential fluid. I have seen many a Jeep rear ends messed up for this exact same reason.
  10. Jun 28, 2010 at 12:00 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    problem is the drum brakes, not with the differential. not only tacomas, but other trucks will lock up if you get the inside of the drums wet by submerging them into water. The brake dust inside the drum acts almost like glue if you get it wet and let it sit. If tacoma came with rear disk brakes then this wouldn't be a problem.
  11. Jun 28, 2010 at 3:02 PM
    jtav2002
    Josh
    Reading, PA
    I hope it's just the brakes being stupid and not the differential preparing to grenade haha.
    Also important to note that my brakes did start squealing at times ever since I started using the truck for the boat a month ago.
  12. Jun 28, 2010 at 3:27 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Sounds like the rear brakes locking up. Where I fish I sometimes have to put all four tires in the water to launch and when I come back after fishing my brakes will occasionally make all sorts of noises for a bit before the rust/grime is gone. I had them lock up once too. I freaked for a little bit before I thought about the rear brakes not releasing and rusting to the drum.
  13. Jun 28, 2010 at 5:10 PM
    DWreck
    Derek
    Las Vegas, NV
    Carry a ball pein hammer
