Rear axle not centered under truck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AZMonkey, Apr 27, 2017.
  1. Apr 27, 2017 at 2:01 PM
    AZMonkey
    AZMonkey [OP] Well-Known Member
    AZ
    2017 DCSB TRD OR 4x4 MT Quicksand
    Am I missing something????????????
    My rear tire on the passenger side sticks out much farther then drivers side.
    Actually a PRO owner pointed it out. It was the same as his truck.
    WTH? Have not seen it discussed. Does everyone consider it normal?
    Yes I checked bed alignment with uncalibrated eyeballs.
    What gives?
  2. Apr 27, 2017 at 2:04 PM
    Humboldt_Homie
    Humboldt_Homie If you're not first, you're last.
    16 TRD OR DCLB
    Bilstein 6112 front, 5100's rear with blocks, camburg UCA, 17" XD's with 285/70/17 AT 3's and a blackout front grille.
    Tighten the lug nuts on the passenger side.
    usadaytrader, R.Shaw and T4RFTMFW like this.
  3. Apr 27, 2017 at 2:05 PM
    R.Shaw
    R.Shaw Well-Known Member
    2016 Tacoma 4X4 TRD
    It's your bed alignment not the axle.
  4. Apr 27, 2017 at 2:05 PM
    AZMonkey
    AZ
    That actually made me laugh. Should have expected. Lug nuts loose?
    Humboldt_Homie likes this.
  5. Apr 27, 2017 at 2:07 PM
    AZMonkey
    AZ
    So easy fix then?
  6. Apr 27, 2017 at 2:07 PM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    The side to side alignment of your axle is dependent on the leaf springs and the mounting points on the frame. If you would like to know if its the axle or bed that is off, measure off of the frame rails.
    Most likely it is the bed.
  7. Apr 27, 2017 at 2:08 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    4 bed bolts. Loosen, reposition bed, tighten.
  8. Apr 27, 2017 at 2:18 PM
    AZMonkey
    AZ
    Sleep deprivation not helping.
    I just now went out and measured off frame.
    It appears it is both axle and bed.
    Great build quality!
    I just had FJ Trail Team black wheels installed. They are 1/2 inch wider and offset a little more.
    It really shows now.
  9. Apr 27, 2017 at 2:48 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Pic's..
    TacoFister likes this.
