Rear axle off center?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Oct 1, 2010.
  1. Oct 1, 2010 at 7:04 PM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Boulder County
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    Don't know how else to describe it but when I look at my truck from the side, the rear wheel is much closer to the rear portion of the wheel well than it is to the center of the wheel well. I've had this truck for 11 years and first only noticed this a couple of weeks ago.
    This is an old picture and not exactly straight on, but you can get the gist. Trust me my eyes are fine, it is definitely off center for sure.
    Is this normal for completely stock Tacomas? Something of note, about two years ago I had a shop (my friend's) redo my shocks/struts all the way around
  2. Oct 1, 2010 at 7:06 PM
    Matic
    Matic The "OFG" Baby!!!
    Richard
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    I flexed my first gen the other day and buckled the bottom of my left rear. I would say its normal. The right side however sustaind no damage.
  3. Oct 1, 2010 at 7:31 PM
    Matic
    Richard
    Easley, SC
    err.. you have the wrong topper for your truck.
  4. Oct 1, 2010 at 7:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Only way to accurately tell Is to measure it in the well. Make sure its not the bed thats crooked.
  5. Oct 1, 2010 at 7:35 PM
    Madjik_Man
    Boulder County
    Negative
  6. Oct 1, 2010 at 7:36 PM
    Madjik_Man
    Boulder County
    Measure from front edge of well to leading edge of tire and rear edge of well to trailing edge of tire?
    Without doing so I can all but guarantee the latter measurement will be less than the former.
    But I'll do it and report the numbers
    (after I go camping this weekend)
  7. Oct 1, 2010 at 7:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    correct, but like I said, make sure the bed is centered first
  8. Oct 1, 2010 at 8:00 PM
    Madjik_Man
    Boulder County
    How do I go about doing that?
    btw - thanks Chris, your knowledge is invaluable
  9. Oct 1, 2010 at 8:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    make sure the gap between the cab and bed is equal. Also, Measure the distance to the frame to the side of the bed on both sides, front of bed, and rear. Glad to help :)
  10. Oct 1, 2010 at 8:48 PM
    Matic
    Richard
    Easley, SC
    Then you need to remove your 3rd brakelight for it to fit correctly.
    The profile of the camper top does not match the profile of the cab.
    There are a few differant models of toppers for first gens.
  11. Oct 1, 2010 at 8:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    He has the right one. The cap for the regular cabs are more vertical.
  12. Oct 1, 2010 at 8:55 PM
    Matic
    Richard
    Easley, SC
    Wow. That looks horrible. Sorry.
    And I think th other cap there were referring to has a sharper cut at the bottom and then curves.
  13. Oct 1, 2010 at 8:57 PM
    Matic
    Richard
    Easley, SC
    nm. were not talkin caps.
  14. Oct 1, 2010 at 8:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    More than likely, its the angle the photo was taken. it looks no different to me, than all the other tacomas with the same cap.
  15. Oct 1, 2010 at 10:21 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    My tires rub on the rear portion of the fenders because the axle is positioned back from center of the wheel wells. I think there are re location kits to move it forward a little but to correct the rubbing (I have 33's BTW)
  16. Oct 1, 2010 at 10:26 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Yup that is normal. I remember reading about this somewhere when I was looking for Deavers. I also remember reading that the Deaver 8 pack will move the rear end slightly forward. How much that is I don't know but I do remember having to kick my rear end foward to get the pin to line up when I put them on.
  17. Oct 1, 2010 at 10:41 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    No way! I have the same problem with my truck!
    No, but seriously, that was after I ran into a giant rock going way too fast offroad.
    I sheared the centering pin, and messed up my leaves royally, but I was still able to unbolt the U-bolts, shove in a new centering pin, reset the pack, and bolt it back together.
    Since the U-bolts were bent they slid back on both sides to past where yours are, but the tires still clear under full compression (barely). I'm gonna buy some Old Man Emu Leaf Packs someday, but don't have the time or money lately...
    Look at your driveline. It extends, and you can tell by the grease line on the extension part if it has extended recently.
    If it's too far back, unload the rear, unbolt the U-bolts, try getting some new centering pins (I just used a bolt and nut that fits...), and/or take ratchet straps and try jamming it forward.
    Hope that helps.
  18. Oct 2, 2010 at 9:02 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    Now: 12 T4R SR5 Then: 99 - 3.4L SR5 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
    Yours doesn't look much different than mine. I'd say just chalk it up to another quirk of the 1st gens.
  19. Oct 2, 2010 at 5:34 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    mine is the same way, it hits the rear of the fender before it even makes it within a inch of the front..
