Rear axle off center
Discussion in '3rd Gen. Tacomas (2016-2023)' started by T&R&D, Apr 10, 2025.
  1. Apr 10, 2025 at 4:25 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Bed misalignment is somewhat common on Tacoma's but easy enough to adjust.
    tonered likes this.
  2. Apr 10, 2025 at 4:30 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I’ve read this is relatively common on these trucks. Meaning, you’re not the first to post about it. If a 4-wheel alignment comes up clean then it’s baked into the final product. Shifting the bed might or might not clean it up some but if it drives true then it depends on how much the aesthetic bothers you.
    YoshiMara likes this.
  3. Apr 11, 2025 at 10:19 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    It's not bad.
    There's people here that are always here that know nothing more than what they've "read" here. No real world experience but they feel the need to comment on everything.
    I was treated like crap when my acct was new.
    Been driving tacomas for 22 years but because my acct was new, many acted like I don't know anything.
    Stick around.
  4. Apr 11, 2025 at 10:20 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I need pictures to be more helpful.
    gudujarlson likes this.
  5. Apr 11, 2025 at 10:26 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    What I was wondering is if the leaf pack shifted a little. I think it's possible to have the leaves crooked and still be on the center pin.
    What I would try is, with the truck on the ground loosen ALL the ubolts.
    Rock the truck a little bit so the leaves can settle into place then retighten the ubolts.
  6. Apr 11, 2025 at 10:26 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Sorry so triggered. There always the few smart assses. But OP if you have checked bed alignment and the alignment specs are in order. There is no fixing it. You could try loosening the ubolts and shifting the axle maybe you get a 1/4” corrected. But as I’ve said earlier with a live axle set up for the axle to sit to one side or another is absolutely normal.
    bkhlrTaco's and SH10151 like this.
  7. Apr 11, 2025 at 10:27 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Yup. This ^
  8. Apr 11, 2025 at 10:27 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Pictures would help us OP?
    Chew and gudujarlson like this.
  9. Apr 11, 2025 at 10:31 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Don’t spend money chasing this.
  10. Apr 11, 2025 at 10:31 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    It sounds like you are capable of doing the work yourself, maybe source a nearly new stock leaf pack locally? They have little to no resale value, so with some searching you can probably find a set of take-offs.
    Of course that's IF you are staying at stock ride height and don't plan to carry heavy loads.
    bkhlrTaco's likes this.
  11. Apr 11, 2025 at 10:37 AM
    gotoman1969
    This OP. A leaf pack won’t fix this. Now if the bushings on your current pack are all worn to hell maybe. Hate to see you spend money and not really fix it. My truck is approx 3/4” and some days if I’ve gone down the trails it may be a 1/2”. Just the way the rear suspension works.
    soundman98 and SH10151[QUOTED] like this.
  12. Apr 11, 2025 at 11:24 AM
    T&R&D
    T&R&D [OP] Member
    If a moderator sees this, please permanently delete all this and my account! I’m done with forums in 2025.
  13. Apr 11, 2025 at 11:27 AM
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    The main leaf spring on each side is connected to the frame at the bushings, front and rear. Even if your shorter leaves are twisted, they are twisted around the center pins, which go through the main leaf. That’s not going to allow your axle to move side to side much.
    Even if you loosen your u-bolts and are able to shift the axle to the center, when you re-tighten your u-bolts and drive the truck it will probably pull the axle back to where it was. (Caveat in point 6 below).
    All that said, here are some other possibilities to consider:
    1.) You might have a broken or loose center pin. That would allow your axle to move off-center, especially under the influence of the RAS.. You would need to remove the U-bolts and bump stops, and lower the axle from the springs to check them.
    2.) You might have worn-out or torn bushings or a broken bolt in one of the ends of your leaf springs or shackles. On a 2022, I kind of doubt that’s the case but it’s worth checking.
    3.) You might have a bent shackle hanger (the J shaped thing that hangs off the rear of your frame to hold the shackle). Uncommon, but it happens.
    4.) The RAS might be putting unequal spring tension on your axle, shifting it to one side. Given that the shocks on these trucks are mounted asymmetrically, this is a real possibility.
    5.) You might have a cracked leaf spring or a broken u-bolt.
    6.) Finally, take a look at the angles of the two plates under the axle housing that the u-bolts pass through. Are they both at the same angle? If they are not, that’s good evidence that your u-bolts were not tightened evenly. (Even if the plates are even) loosen the u-bolts and tighten each one a little bit at a time, ensuring they are all even, finishing each bolt with a torque wrench to the same spec. (People disagree on what that spec should be, but I personally do 75 ft. lbs. The FSM says 37, which is almost certainly a misprint. Most aftermarket spring and bolt manufacturers call for something in the range of 90 ft. lbs. I have found my springs squeak less at 50 ft lbs, so I split the difference and do 75.) (This probably isn’t going to fix your offset axle issue but it’s worth checking and trying while you’re under there.)
    SH10151 and gudujarlson like this.
  14. Apr 11, 2025 at 11:30 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    You are a very patient man. I salute you. :)
  15. Apr 11, 2025 at 11:34 AM
    #35
    gudujarlson
    Minnesota
    If readers are confused, it appears the OP has deleted most of his posts. It must have have been a very rough calculus exam … or it’s Friday.
    soundman98, 5465, STEELeR43 and 2 others like this.
  16. Apr 11, 2025 at 11:36 AM
    #36
    T&R&D
    T&R&D [OP] Member
    wow, thank you so much Tom, you are the kind of man I would want to work with in a mechanic shop!!!! I will save this info for future reference! You’re the man!
    I’m still done with this forum :(
  17. Apr 11, 2025 at 11:37 AM
    #37
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Quitter. o_O
  18. Apr 11, 2025 at 11:44 AM
    #38
    TomHGZ
    One last possibility — I once saw a Canadian Tacoma that had a seized rear shock that was causing variety of problems with the rear end. It wasn’t completely seized but it was seized enough to mess things up.
    soundman98, SH10151 and gudujarlson like this.
  19. Apr 11, 2025 at 11:45 AM
    #39
    TomHGZ
    Just underemployed and bored. :rolleyes: But I do like these puzzles.
  20. Apr 11, 2025 at 11:54 AM
    #40
    TomHGZ
    I’ve owned Tacomas for twenty years now, and Tacomaworld has been a MASSIVE help for me. I’ve diagnosed problems, learned to fix them on my own, made dozens of modifications and improvements to my trucks, bought and sold parts, and have made good friends here and gone on 4x4 adventures with them. Don’t quit.
    Some people say rude things, sometimes intentionally (because they are personally weak and miserable, and therefore deserving of your pity), but often because they simply don’t understand how they are coming across to you. That’s everywhere, and you are not going to escape that by quitting Tacomaworld. Don’t quit.
