Rear axle oil seal
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toy4Life, Jul 9, 2008.
  1. Oct 17, 2014 at 1:43 PM
    #41
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
  2. Mar 1, 2016 at 12:46 PM
    #42
    -bLAckwidows
    -bLAckwidows New Member
    08 Tacoma Trd off road
    Does anyone have any pictures to give me a idea how to fix a rear diff leak on my 08 pre runner.
  3. Sep 25, 2020 at 11:46 PM
    #43
    Brie
    Brie Well-Known Member
    Brieanna
    CA
    2001 Tacoma TRD, Prerunner & 2016 Taco Sport
    Is there another name for the serration bolts? Cant seem to find them...
  4. Sep 25, 2020 at 11:59 PM
    #44
    jruiz555
    jruiz555 Well-Known Member
    Had the issue on my 4runner, after replacing the seal 3 times, it turned out to be the bearing... I would check the axle housing for scratches near where the abs ring would sit. It didnt happen till i engaged the rear locker, after that the bearing had a lot of play, and leaked into the drum brakes. easy repair is to just get a axle side with good bearings and install it.
  5. Oct 1, 2020 at 1:25 PM
    #45
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    I got some new bearings installed. It was just $100 for labor with a 24 hour turnaround time. The shop put in new retainers at no extra cost (a $25 value) The Beck Arnley bearings from Rockauto.com were $25 each and are made by Koyo Japan (same as OEM that are $89 ea.) with new inner and outer seals the leaking has stopped. New rear brake shoes were needed to replace the oil saturated ones. The diff breather itself is a simple piece that can be removed and cleaned out; there is not much benefit to buying a new one. It is good to have rear brakes that work again.
    And wow! What an old thread.
