rear axle problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by rab89, Jan 2, 2010.
  1. Jan 2, 2010 at 12:01 AM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    trying to keep this short
    1 year ago, had my rear axle seal replaced, started leaking again, started to hear a funny growl on my christmas vacation drive, and a ringing type of noise when I let off the gas and there is back pressure. so i bought another one and replaced it, refilled the diff, noise is still there. drove an hour today to get home, then I noticed there was a hissing sound coming from the wheel area, sounded like a punctured tire, but it surely was not, then I put my hand near the wheel and it was HOT. the heat may be from the brakes, as i might have messed up the rear, but I'm not sure. where should I start looking for my problem? thanks
  2. Jan 2, 2010 at 12:37 AM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Did you replace the wheel bearing when you did the seals.
  3. Jan 2, 2010 at 12:57 AM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    no sir, should i do that next?
  4. Jan 2, 2010 at 9:56 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    Ttt
  5. Jan 2, 2010 at 11:19 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    bearings!!! your gasket my be bad get a new one. dont let it run dry or youll be out a grand!
  6. Jan 2, 2010 at 11:25 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    ok well things just got more fun, I'll pick up new bearings tomorrow, but I think it was the brakes, when I was cleaning everything up before putting it back together I adjusted the brakes (by accident) and I think they were rubbing the whole drive back and the heat was the brakes.(facepalm) It didn't feel like it though..
    anyways, I just went out to bring the truck in the garage, and my right rear tire doesn't wanna move, I can tell it's the right rear from the way it pulls, I didn't give it much cause I didn't wanna break anything, so, should I just drive it into the garage and force it to move, or whaaat? I could take it apart where it is, but it's raining and cold out...
  7. Jan 2, 2010 at 11:26 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    after I first started hearing the noise I added some oil, I was able to fit about half of a bottle, do you think it got too dry?
  8. Jan 2, 2010 at 11:33 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    hmm, anyone know if it'll be ok to force it? generally it's the wrong thing to do but who knows
  9. Jan 2, 2010 at 11:34 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    it really depends on whats causing it to be locked but forcing it is probably NOT a good idea
  10. Jan 2, 2010 at 11:36 PM
    Hambone155
    omaha
    shit my breaks are warped as hell. but they only shake around 40-50mph unless im on them hard.
  11. Jan 2, 2010 at 11:36 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    k, I guess I'll jack it up and roll it into the shop on the jack. FML harder please
  12. Jan 2, 2010 at 11:38 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    if you have access to a dolly of some sort i would suggest that over rolling with the jack
  13. Jan 2, 2010 at 11:55 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    decided on outside, the rain's holding up, i have the tire off, but the drum sure is stuck, any advice?
  14. Jan 3, 2010 at 12:30 AM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    well I got the drum off finally, no signs of any carnage, there is a bit of oil though, might be the other axle seal?
  15. Jan 3, 2010 at 12:40 AM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    as the cause for the wheel seizing?
  16. Jan 3, 2010 at 12:54 AM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    when I had the brake apart to do the axle seal, I pulled the e brake cable, this made the brakes tighter, it was hard to get the drum back on so I should have known. but basically brakes were tightened, making them rub on the drum.
  17. Jan 11, 2010 at 6:22 PM
    JustinF
    JustinF New Member
    alberta, canada
    2000 tacoma 4cyl
    qu? When in h4, l4 only 2 passenger tires spin
    Sincerly, concerned
