Rear Axle problems??
Discussion in '1st Gen. Tacomas (1995-2004)' started by landonbrady, May 13, 2024.
  1. May 13, 2024 at 10:25 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You can see the four forward most bolts easily - one set above where the gas tank is and directly across from it and another set at the top of the wheel arch. The rear most ones are up in a hole on each side of the frame right near the very end and you use an extension with a 12 or 14mm socket to remove them. I redid how the bed is mounted so I can’t remember exactly what size they are but they’re all the same.
    wilcam47 likes this.
  2. May 13, 2024 at 10:28 PM
    landonbrady
    landonbrady [OP] Member
    1997 Tacoma 2.7l
    Alright that sounds easy enough. Should I remove them or just loosen them? After I do that, would I just pull back on the bed until I find the sweet spot? Thanks
  3. May 13, 2024 at 11:10 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Just loosen them - they all have about 1/4 - 1/2” of space to move around in the frame in each direction when they’re centered in the holes. Remove them if it’s not working and look for any bent areas at the mounting areas.
  4. May 14, 2024 at 5:54 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    prob youtube video but shouldnt be too bad.
  5. May 15, 2024 at 2:26 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    good news......your fine man i wouldnt worry about anything
    bad news.....there is not alot of adjustment on bed bolts
    what is slightly swayed up is the actual frame
    can be fixed NP
    but
    bed/bumper has to be removed
    then a bodyshop with a frame machine has to pull frame back to specs
    depending on how many frame control pts and including the bed and bumper removal and today's labor pricing
    $800 to $1200 no paint included (dont need paint unless you paint/repair cab)
  6. May 16, 2024 at 1:52 PM
    mike759
    mike759 Well-Known Member
    Colorado
    2002 Xtra cab TRD off-road
    2.5" lift, JBA UCA, OME rear leafs, 33s...
    You said it came from a dealership after the auction? If so you should show them the damage they failed to mention.
    ControlCar likes this.
