Rear axle questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01sctaco, Jun 29, 2018.
  1. Jun 30, 2018 at 12:44 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    you can. requires minor cutting and two studs to be drilled/moved. couple hour project.
    If OP lives near az, I have an entire axle with elocker/4.10's and ABS up for grabs.
    Running Board Man likes this.
  2. Jun 30, 2018 at 1:13 PM
    01sctaco
    01sctaco [OP] Member
    Josh
    01 4dr 4wd trd
    3” lvl kit, rancho quick strut. 35s
    I’m all the way in sc bro. But thanks for the offer
  3. Jun 30, 2018 at 1:22 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    fer shure. for reference, here are the modifications required. Lowrange not only sells the seals/studs, but also a tap and other hardware.
    Stout890 likes this.
  4. Jun 30, 2018 at 2:58 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The 6 lug 1st gen 4wd/prerunner open diff known as the "8.4" can not swap into the e-locker 8" housing or the other way around without a machine shop and deep pockets.
    The often mentioned e-locker "swap" (pictured above) requiring a "minor bit of grinding, drilling/tapping and bashing" is for an 8" e-locker 3rd into an open 8" housing. 1st gen 6 lug Tacos did not come with an 8"open housing. The swap was made popular years ago with 3rd gen 4skinners as they all had the 8" housings. An e-locker diff gasket placed on the 8" open housing made for a perfect template for the grinding/drilling.
    1st gen standard open diff.
    1st gen e-locker diff.
    GillyMac and License2Ill like this.
