rear axle regear
Discussion in '5 Lug' started by Joels98taco, May 30, 2011.
  1. May 30, 2011 at 3:10 PM
    Joels98taco
    Joels98taco [OP] Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    hey guys i got a few questions about the regear. looked but i think everyone is running bigger tires than me.
    i have 29's on stock gears but was wondering what gears i should get and brand?
    next question is it gonna throww off the speedo? its a little off like 2mph nothin big.
    is it gonna help with mpg?
    and anyone know a good cheap place in socal? how much? preferrably in san bern, oc or la county
    thanks in advance guys :D
  2. May 30, 2011 at 3:17 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    its slower than before and mpg took a good hit
  3. May 31, 2011 at 8:57 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    4.10 gears
    Ya ur speedo is off by 2-8mph depends how fast ur going. The faster u go the more ur speedo is gonna be off.
  4. May 31, 2011 at 9:00 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    If your main reason is MPG's don't it would take years if ever to recoup the cost of a re-gear your not going to see that much more.
  5. May 31, 2011 at 5:25 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    well its my dd and if i regear i will probably get a locker for wheeling too
  6. May 31, 2011 at 5:48 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    is it a good locker? and where can i get one of those?
  7. May 31, 2011 at 9:13 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    It's an auto locker or "lunch box locker" meaning that it locks up when you are going straight and unlocks when going around turns. There is no "on" or "off" switch like with an ARB or the factory e-locker. The lockright is made by Richmond Gear and can be purchased through any of their dealers, JEGS, Summit, East Coast Gear Supply, and Randy's Ring and Pinion to name a few. The lockrights are more for dedicated off road rigs as they tend to be noisier when they lock/unlock. The powertrax unit is supposedly quieter and thus a little more street friendly, although I'm not sure they make for your diff. Some folks don't like them because the locker can't be turned off when driving on slick road conditions like snow or ice. As far as I know they are pretty reliable. I haven't run one myself, but I was about to at one point.
  8. Jun 1, 2011 at 6:27 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    for sure ill look into those thanks man :rolleyes:
  9. Oct 23, 2011 at 10:47 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Total Chaos Mid Travel, Sway away coilovers,31x10.50x15 goodyear wrangler authority's
    Why is it better?
