Rear axle replacement help.
Discussion in '1st Gen. Tacomas (1995-2004)' started by toypower, Aug 10, 2014.
  1. Aug 10, 2014 at 3:38 PM
    toypower
    toypower [OP] Well-Known Member
    corey
    Niceville FL
    98 Reg Cab Tacoma
    Sas swap, dana 44 high pinion front, Corporate 14 bolt locked, disc brake conversion. 8 inch superlift springs on 39.5 iroks, 5:38 front and rear. Hydraulic assist, 3 inch body lift, Yukon axles front/rear, bilstein shocks, CAI, rock ripper header.
    I've been searching the internet for months now trying to get info on this rear axle swap I'm planning on doing and can't find any info. I see plenty of trucks with the same setup I want to use, but they give no info on putting it in. I have a 98 regular cab tacoma that I'm putting a full width corporate 14 bolt cucv in. I measured my springs center to center and came up with 39 1/4. I just want to be sure I have this measurement right,and I was wondering if anyone had any tips on squaring the rear axle up right? I just wanna get this right the first time and not deal with it again. any help is appreciated.
