rear axle replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by malander, Nov 24, 2010.
  1. Nov 24, 2010 at 3:05 PM
    malander
    malander [OP] Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Just out of curiosity does anyone know what all would be needed to throw a rock assault rear tacoma axle housing in the back? i would assume the chromoly axle shafts they sell as well and spring perches and shock mounts but what else? http://www.trail-gear.com/tacoma scroll down some to see it
  2. Nov 24, 2010 at 3:11 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Not sure, but the stock tacoma axle is very strong. Not much reason to change it.
  3. Nov 24, 2010 at 3:53 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    A complete third member that'll fit in that housing, gears / setup,bearings, axle shafts, more bearings, more seals, entire brake kit, spring perches, shock mounts and there's probably more that I'm missing.
    Very $$$$$$$$$$$$$$$$$$$$$$$$$$$ once you add it all up.
  4. Nov 24, 2010 at 10:08 PM
    malander
    max
    01 limited trd 4x4
    im not quite certain why i was wondering, i guess im just tryin to get the basics of everything aftermarket thanks for the info
