Rear Axle Runout Tolerance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Overlandin, Jun 4, 2024.
  1. Jun 4, 2024 at 12:21 PM
    Overlandin
    Overlandin [OP] Active Member
    2006 Tacoma TRD Sport 4x4 Access Cab
    Does anyone have rear axle runout specs? I've had an issue with what I originally thought (knew) was warped drums. They were definitely out of spec. After replacing, still encountered a rear end hop under braking. Pulled the new drums off and measured tolerance. They're flawless. Checked the hub runout and found it to be at 0.035". Any insight as to if this is out of tolerance? Seemed significant to me.
    Thanks.
  2. Jun 4, 2024 at 1:41 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
  3. Jun 4, 2024 at 2:03 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    Rembered watching this video a few months ago. Not a Tacoma, but probally a similar rear end. In this video, he says the max run out is 0.05mm or 0.002" for the axle he is working on.
    Around minute 12 is where the dial gauge is used to measure the bad axle and then the good axle on the other side.
    https://youtu.be/fRkedFQkrqs?si=TqHRwz5KeROIwD4V
  4. Jun 4, 2024 at 5:29 PM
    Overlandin
    Exactly the info I needed. Thank you both!
