Rear Axle Seal Issues and Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrewtheadventurer, Apr 30, 2018.
  1. Apr 30, 2018 at 3:38 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Add a UV die to the diff. Drive 500 miles and check for leaks. Thatll prove exactly where the leak is, if it exists
    ItalynStylion and tcjacado like this.
  2. Apr 30, 2018 at 4:03 PM
    andrewtheadventurer
    andrewtheadventurer [OP] Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Ahh this is quick and easy. I will do this now
  3. Apr 30, 2018 at 4:04 PM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    This wont cause any issues in the diff by changing the viscosity of the gear oil?
  4. Apr 30, 2018 at 4:41 PM
    Muddinfun
    Muddinfun Well-Known Member
    Watch that video that I posted a link to, from 15 minutes to 17 minutes.
    "paid for a job and they screwed it up"
  5. Apr 30, 2018 at 5:04 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I would highly suggest looking at the rear diff vent. If the diff vent is rusted shut you will blow seals out again and again. It might be best practice to check this part at every oil change, replace this part every few years or relocate it like many people do.
    tcjacado likes this.
  6. Apr 30, 2018 at 5:19 PM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    This is very true and often overlooked! I checked this after my second one blew and it is good to go!
    Good insight!
  7. Apr 30, 2018 at 5:21 PM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Whaaaat if you pay for it then it will ALWAYS be done right! \s
    I kind of feel bad for second guessing thier work but i have heard too many horror stories not to double check after any work is done on the vehicle.
  8. Apr 30, 2018 at 5:29 PM
    ProForce
    Anthony
    Alaska
    You only add about 1oz or less. It's safe for transmission fluid which is essentially the same as diff fluid. Dealers use it. Don't see what harm it could be.
  9. Apr 30, 2018 at 5:32 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    And in their defense:crapstorm:, if they just did the seals only/no bearings, they may have not noticed if the collars were in the correct position. They would have to get a tape measure out and check side to side.
  10. Apr 30, 2018 at 5:54 PM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    ahh this is an opportunity for a measure to be overlooked
  11. Apr 30, 2018 at 6:02 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Wait for it...
    ...Ask me how I know? LOL!:rimshot:
