Rear axle seal leak: Bearing replacement needed due to gear oil contamination?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by D-Bag, Oct 24, 2023.
  1. Oct 24, 2023 at 8:59 AM
    D-Bag
    D-Bag [OP] Well-Known Member
    Derik
    2014 Tacoma Baja
    Good morning, I had a rear axle seal go out so I replaced both axle seals, left and right. I also had to replace brake shoes due to gear oil contamination. The question I have is that for gear oil to get to the brake shoes does the gear oil pass thru the rear wheel bearing? If gear oil passes thru the bearing does that bearing need replaced?
    Thanks!
  2. Oct 24, 2023 at 9:01 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
  3. Oct 24, 2023 at 9:04 AM
    D-Bag
    Derik
    2014 Tacoma Baja
    Yes on all accounts? Bearing needs replaced?
    Thanks!
  4. Oct 24, 2023 at 9:04 AM
    TireFire
    Olympic Peninsula
  5. Oct 24, 2023 at 9:09 AM
    Bishop84
    Bishop84 Well-Known Member
    Basically even if you degrease everything it’s still too late, the bearing is full of oil and will sling oil on all your new brake parts.
    You can do it, but if the axle is out just get the bearing replaced.
  6. Oct 24, 2023 at 9:19 AM
    D-Bag
    Derik
    2014 Tacoma Baja
    Sounds good. Thanks!
  7. Oct 24, 2023 at 4:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’m a hack.
    And I do things I shouldn’t do sometimes.
    My axle seal leaked back in 2017 with about 90k miles on my on my truck.
    I am at 167k now. I did not replace my bearing. I even kept my old shoes.
    Soaked them down with carb cleaner and let them soak while doing rear seal.
    Just replaced my shoes this year at 160k. Still on the same rear bearing….:eek:
    That said, don’t be like me.
    If you can afford to have the bearing replaced, replace it.
    I was in a pinch, I had 1 day to fix the leak. And no way to press on/off bearings.
    I tossed a seal in it and “got lucky”.
