Rear axle seal replacement estimate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GimmeTacoma, Aug 29, 2022.
  1. Aug 29, 2022 at 11:56 AM
    Southendglass
    Southendglass Well-Known Member
    Tony
    Charlotte
    2022 sport access
    My bearings were getting bad letting the axle move around and that’s what wore out my seal.
  2. Aug 29, 2022 at 2:32 PM
    GimmeTacoma
    GimmeTacoma [OP] I LOVE the tacos
    Jacob
    2009 Prerunner double cab AT black
    not much tbh
    That is what my friend told me more than likely happened. He’s a retired mechanic and said I need to replace the bearings…he was trying to talk me into just having a shop do it all for me. I’m a young college kid with not a ton of money and I’d rather learn how to fix it myself.
  3. Aug 29, 2022 at 4:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    My axle seal blew out when the rear diff breather got stuck closed.
    That was at 79k miles. I’m at 135k now. Still on the same rear bearing.
    The rear bearing is a PITA to change. Id make sure it’s bad before I paid someone to do it.
    I mean, yeah. You probably should replace it. But you said you didn’t have a lot of money and you’re a college student. So maybe you can save up some money and do the bearing later. Like I said, I got 5+ years out of my rear after the leak.
    GimmeTacoma[OP] likes this.
  4. Aug 29, 2022 at 4:17 PM
    GimmeTacoma
    Jacob
    not much tbh
    my truck has 204k miles on it, so they probably just need to be replaced. I have enough money to do this and have plenty left for security, so $300 to have the bearings pressed isn’t that bad and I can get bearings for abt $150 a pair. The reference to money was mainly that I don’t want to spend 3k to have someone else fix everything wrong when I can spend 1k and do it myself.
  5. Aug 29, 2022 at 4:20 PM
    TnShooter
    Deogee
    STOCK
    Yeah. At 204k you should go ahead and do it. Sorry to hear it man.
    I know how unexpected expenses can be.
    At least you have the money to get it done. :thumbsup:
  6. Aug 29, 2022 at 4:21 PM
    GimmeTacoma
    Jacob
    not much tbh
    Yeah, thx man!
  7. Aug 29, 2022 at 4:34 PM
    GimmeTacoma
    Jacob
    not much tbh
    Lol, how do you have an 07 with that few miles. That’s crazy!
  8. Aug 29, 2022 at 4:39 PM
    TnShooter
    Deogee
    STOCK
    It was a typo. I actually have 155k
    Sorry about that. :)
  9. Aug 30, 2022 at 3:08 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    If you have to replace the rear bearings it's best to take it to a machine shop that has a huge press. I tried to remove them with a 12 ton press and the bearings just laughed at it. Used a 20 ton press and still wasn't enough. The machine shop had to cut the collar retainer to get that thing out cuz their press wasn't enough either.
    JAGCanada and GimmeTacoma[OP] like this.
  10. Aug 30, 2022 at 9:58 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Rear bearing aren't too bad if you have a press and the tool (which is cheaper on Ebay). You can also pull the axle yourself (pretty easy again), and take it to a local shop and ask them to press the old one out/new one in.
    Once you take the nuts out (and disconnect the brake line and parking brake cable), the axle just slides out. While it's out, doing the seal is easy - just be careful about nicking/damaging the seal when you're putting the axle back in.
    If you live in NH, you can borrow my axle press tool I got from Ebay that is sitting in my garage - I even have that adapter so you don't have to swap the bolts to longer ones in order to press.
  11. Aug 31, 2022 at 10:17 AM
    GimmeTacoma
    Jacob
    not much tbh
    Thx man, I'm in KS so unfortunately can't but appreciate the offer. I'll be taking the axles to a shop they'll press my bearings for abt 300
