Rear Axle Seals! Retainer Rings?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AMOCAT911, Apr 11, 2013.
  1. Apr 11, 2013 at 3:10 PM
    AMOCAT911
    AMOCAT911 [OP] Member
    Blair
    NL / Canada
    06 TRD
    Just wondering from those of you who have replaced the rear axle seals on your Tacoma if you replaced the retainer rings as well? I'm not sure how you would determine if these would require replacement.
    Any information appreciated.
    Blair
  2. Apr 11, 2013 at 10:52 PM
    RyanK1
    RyanK1 Well-Known Member
    Penticton, British Columbia
    2006 Tacoma TRD Sport
    Bilstein 5100's @ 2.5, TSB rear with block spacer, Procomp ES9000's, CBI Moab 2.0 front bumper, swaybar removed, DIY HiLift mount, Rear diff breather mod, ABS Kill Switch, Flowmaster 40 series muffler, Superwinch 8500
    I replaced the rear seals about a year ago but used the original rings. Im assuming that if they were loose or damaged in any way they would need replacing, otherwise Im sure its fine.
  3. Apr 11, 2013 at 10:56 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    If they're loose you have bigger problems. If there are any knicks or scrapes where the seal rides or if it's cut too deep of a groove it will need replaced. However, I wouldn't replace it unless it keeps leaking as it's not a very easy job. Mine didn't even really have a groove cut into them with 60k miles on the truck so I'd assume they're probably good the life of the truck or at least until you do your wheel bearings. So really only if there are any knicks or dings etc where the seal rides.
    This might help?
    http://www.tacomaworld.com/forum/technical-chat/246760-2nd-gen-rear-axle-bearing-diy.html
  4. Apr 11, 2013 at 11:54 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    I replaced both rear axle seals and reused the retainer rings. Been fine for almost a year now
