Rear Axle seems off center, sitting to the right...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mjohn617, Jun 27, 2010.
  1. Jun 27, 2010 at 6:19 PM
    mjohn617
    mjohn617 [OP] Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    Haha...not doing it...can't make me!
    I finished my lift a couple of weeks ago and a guy at the shop I was using pointed out my rear wheels, the right one stuck out more than the left. I did a measurement that day and could not figure it out. So a couple of weeks have gone by, I thought I could get to the bottom of it, I'm running out of troubleshooting ideas.
    -I have switched rear wheels thinking the new wheels I got at the same time as the lift might have different offset, and check numbers inside the wheel, they check out and the right still sticks out.
    -I have measured my axle at various locations with the frame and seems to be symmetrical.
    -I had a 4 wheel shop take a look when the truck was getting its alignment, did find the reason but said I shouldn't be a problem....not good enough for me!
    Here are the pictures of what I am talking about:
  2. Jun 27, 2010 at 6:20 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Bet you some how the ubolts got a little loose and caused it to move over.
  3. Jun 27, 2010 at 6:25 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    maybe the right wheel got sent in a different offset?
  4. Jun 27, 2010 at 6:36 PM
    mjohn617
    Petaluma, CA
    It was like this the day I installed, I have since re torqued. None of my components loosened when I re-inspected.
    That was my first thought, the ToyTec ULK had the shims, I was thinking the OME Dakars did not sit correctly, checked them out, they look great. So the axles are offset? That is very interesting! I did read an article about certain trucks (moslty american) with bar in the rear that needed to be adjusted or it would pull the axle to the right. We don't have that on our trucks though.
    I was almost positive that's what is was. I have check the numbers stamped on the inside and swapped rear tires, no luck they all match! Plus I don't think the ATX Artillery come in any other offset.
  5. Jun 27, 2010 at 6:45 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Its a soild axle. Don't expect it to be perfect. My axle is not perfectly aligned, oohh well it can't be changed so why worry about it?
  6. Jun 27, 2010 at 6:49 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
  7. Jun 27, 2010 at 6:50 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I remember reading a thread just like this one a while back, and it turns out the guy's bed wasn't centered. Had nothing to do with the axle.
  8. Jun 27, 2010 at 6:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Bingo! Many beds are off just a little bit. Measure the frame out at a fixed point on the bed, and make sure its aligned correctly.
  9. Jun 27, 2010 at 6:56 PM
    mjohn617
    Petaluma, CA
    Wow, really? Maybe I will do some searching and go that route.
    EDIT: I just read the link above, that's probably my problem. Guess I will grab some torx and head back to the shop. Wow, thanks guys!
  10. Jun 27, 2010 at 6:57 PM
    TexasTacoma37
    What do I win? :goingcrazy:
  11. Jun 27, 2010 at 6:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You win a Smiley! :) <------there ya go! :p <-----OOO...Another one!!!
  12. Jun 27, 2010 at 6:58 PM
    desertdude59
    The bed not being centered. That sucks
  13. Jun 27, 2010 at 7:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its not a big deal. Loosen 6 bolts, and adjust if needed.
  14. Jun 27, 2010 at 7:02 PM
    Shawneily
    Shawneily "Its go time, baby!"
    Shawn
    Salt Lake City, UT
    95 Toyota Tacoma 4x4 2.7L
    CBI Rock Sliders, 31x10.15 BF Goodrich KM2's, Stock everything else.
    Is the front tire farther in on that side than the back?
  15. Jun 27, 2010 at 7:03 PM
    TexasTacoma37
    Technically Asgard beat me to it. I hereby donate one of my prizes to him.
  16. Jun 27, 2010 at 7:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Give him this one :p
  17. Jun 27, 2010 at 7:07 PM
    Asgard
    Thanks a lot guys, can't tell you how long I've been waiting for one of those !
  18. Jun 27, 2010 at 7:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :p. I'll give ya another one for future use :p. Now....dont get carried away with them :)
  19. Jun 27, 2010 at 7:09 PM
    TexasTacoma37
    :laugh:
    OP, post your results back here when you check the bed alignment.
  20. Jun 27, 2010 at 7:32 PM
    mjohn617
    Petaluma, CA
    I will
    Ya what is this OP on my username? I just noticed, I was going to check the forum rules but have been forgetting.
