Rear axle shaft removal/install difficulty
Discussion in '1st Gen. Tacomas (1995-2004)' started by Damyota, Dec 17, 2019.
  1. Dec 19, 2019 at 12:30 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    As bad as you said that old bearing was to bad you didn`t take pictures .
    It had to have gotten hot did you never smell anything hot??
    I lean toward a warped housing or bearing race material in the axle tube where the bearing rides
  2. Dec 19, 2019 at 12:53 PM
    Damyota
    Damyota [OP] Well-Known Member
    Dakota
    Virginia
    97 V6 Single Cab
    Toytec coil spring spacer lift, green wire mod, soon to be supercharged ;)
    The only thing I smelt when I drove it was the smell of gear oil afterwards.
    unfortunately it was my sister driving so I’m not for sure what happened. I do know that the night before I was in the truck and it made no unusual noises but the next night that bearing decided to let go and talk
  3. Oct 14, 2022 at 6:10 PM
    phx_4runner
    phx_4runner Member
    Did you ever find out why the axle shaft was difficult to remove and reinstall? I'm having the exact same issue with only one side. I see you're also in Virginia, I'm in the DC area.
