Rear Axle Shim
Discussion in 'Suspension' started by LOLLY, Oct 13, 2016.
  1. Oct 13, 2016 at 8:14 PM
    LOLLY
    LOLLY [OP] Well-Known Member
    Alfredo
    Norwalk, CA
    '05 Tacoma DCLB TRD Sport (RIP) Now '21 TRD Off-Road
    I have a 05 Taco TRD Sport DCLB. Not too long ago the 2" steel block that I had in the back broke on me. I bought new aluminum blocks and it wasn't until after I got home that I noticed that they were not tapered like the previous ones. How do I know what degree shim I should throw in there or if any at all. Here's a pic of the shim for reference.
  2. Oct 14, 2016 at 9:48 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I would consider returning those and getting some 2" blocks that are tapered.
    LOLLY[OP] likes this.
  3. Oct 14, 2016 at 9:59 AM
    LOLLY
    Alfredo
    Norwalk, CA
    I was kind of thinking the same thing. I just slapped those in there since they were the only ones available that I could get same day at that moment. I didn't want to leave my shock compressed without those 2" blocks.
    I see on your website that you offer 2" cast iron blocks with u-bolts. Do you happen to know how long the u-bolts are? I couldn't find that measurement. The reason I ask is because after I got the TSB leaf springs, they are thicker than stock leaf springs leaving my previous u-bolts too short. I'm wondering if you're kit would work for me or if I need to buy the blocks by themselves and the longer u-bolts separate.
  4. Oct 14, 2016 at 10:21 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The are 8.5" Long. We also have 9.5" if you think you need those.
  5. Oct 14, 2016 at 10:23 AM
    LOLLY
    Alfredo
    Norwalk, CA
    Are they measured from the inside of the u or the outside? I measured the ones I have now from the outside but then I read somewhere that they are measured from the inside.
  6. Oct 14, 2016 at 10:36 AM
    billygoat
    billygoat Well-Known Member
    American Southwest
    08 TRD Offroad 4x4
    6” Fabtech Lift, 35’s, lots o’ goodies
    I agree with YotaDan. It's a lot easier to break a small shim than a 2" steel block.
  7. Oct 14, 2016 at 12:17 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Measured from the Inside.
  8. Oct 29, 2016 at 8:12 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    What exactly are the shims for? Are they necessary?
  9. Oct 29, 2016 at 12:54 PM
    LOLLY
    Alfredo
    Norwalk, CA
    As far as my limited knowledge goes, it is to correct the angle of the axle and drive shaft. Then again, there's also drive shaft spacers. I think both are intended to eliminate the vibration on take off that you get after adding a suspension lift.
  10. Oct 29, 2016 at 1:38 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Thanks man
