Rear Axle Swap Suggestions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MojaveMadman, Jul 3, 2017.
  1. Jul 5, 2017 at 7:21 PM
    #41
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    Thought about a trail gear rock assault 9"?
  2. Jul 5, 2017 at 7:23 PM
    #42
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    cheapest would be to just find a new housing then truss it. if you dont mind loosing the ABS then build a junkyard 9 for under 600 bucks.
  3. Jul 5, 2017 at 7:23 PM
    #43
    MojaveMadman
    MojaveMadman [OP] Cali Raised LED
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    I believe they fit the standard description of a standard 9" as discussed above, all factory wheel sensors out the window....
  4. Jul 5, 2017 at 7:24 PM
    #44
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Don't want cheapest, want best option for me. Cheapest is run it... As mentioned above, about $2k is my ideal budget.
  5. Jul 5, 2017 at 7:24 PM
    #45
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    I figured they would but I didn't look into them much at all.
  6. Jul 5, 2017 at 8:47 PM
    #46
    Muddinfun
    Muddinfun Well-Known Member
    I'm curious. Does that Currie housing come with chromolly axle shafts? If not, then it seems kind of pointless to have a super strong housing and center section, but stock strength axle shafts from the bearing to the wheel.
  7. Jul 5, 2017 at 8:54 PM
    #47
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    35 spline from Currie, much larger axles
  8. Jul 5, 2017 at 8:58 PM
    #48
    Muddinfun
    But doesn't it say it uses stock Toyota bearings, and brakes? If so, then it's OEM dimensions from the bearing outward. It's still going to bend the axle shaft.
  9. Jul 5, 2017 at 9:02 PM
    #49
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    I highly doubt that's the cause.
  10. Jul 5, 2017 at 9:09 PM
    #50
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Might not be, I am not well informed on the subject, just what a guy at the shop said.
  11. Jul 6, 2017 at 12:19 AM
    #51
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    You could have gotten 1 tons built-to-the-hilt front/rear with all bling for the price of one of those diamond axles :luvya:
    Custom route is always cooler though...you can really get the axles as you want them...and they are probably a thousand pounds lighter too :D
    Dude...seriously...somebody somewhere must be selling a used axle from a similar truck. You are complicating things too much lol.
    But like I said earlier...if you are going to have hard fun on that truck just might want to bite the bullet and go the custom route. The 2 grand you have is a good starting point :D
  12. Jul 6, 2017 at 6:35 AM
    #52
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    I am really trying not to haha. Want all my shit to work and I want something stronger, in a reasonable budget. Didn't think I was asking too much. Just trying to find the right fit for me... which like a lot of Toyota stuff, seems to be a tall order. Maybe I need to fix it and start to think of a new alternative....
  13. Jul 6, 2017 at 6:52 AM
    #53
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    The highlighted sentence above...famous last words for all of us when we start modifying these trucks LOL. Reality is that reliable, stronger and cheaper rarely go together in the same transaction :laughing:
    Yea if you stick to the toyota stuff it is often a tall order.
  14. Jul 6, 2017 at 7:20 AM
    #54
    Pigpen
    Dan
    Northwest Montana
    They are both 8", FYI. All gen 2 6 lugs are
  15. Jul 6, 2017 at 11:21 AM
    #55
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Im positive you are wrong. I have owned both.
  16. Jul 6, 2017 at 11:31 AM
    #56
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
  17. Jul 6, 2017 at 11:45 AM
    #57
    paranoid56
    San Diego
    14 double cab taco
    ok, go to the junk yard and pick up a 100bucks 14bolt. swap in. you wont brake this ever :D
  18. Jul 6, 2017 at 11:59 AM
    #58
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Hey man, this doesn't jive w your earlier statements about not wanting an overkill solution. Save up then pony up on a permanent fix :thumbsup:
    Fix this once and be done w it.:cheers:
  19. Jul 6, 2017 at 12:54 PM
    #59
    Pigpen
    Dan
    Northwest Montana
    Both are 8" Toyota misleadingly calls them 8 and 8.4
  20. Jul 6, 2017 at 1:33 PM
    #60
    paranoid56
    San Diego
    14 double cab taco
    correct, but the thirds are totally different, 2pinion vs 4. neither are interchangeable. so calling it a 8 vs 8.4 helps with the confusion.
