Rear axle whine/howl at 25mph and up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by teamfast, Nov 9, 2011.
  1. Nov 9, 2011 at 4:28 PM
    teamfast
    teamfast [OP] Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    I have a 1" block lift rear installed over 10,000km.
    24000km on truck.
    persists in any speed above 25mph under accel, decel, neutral, 4wd and 2wd.
    sound does not change with engine speed (i tried it in 2nd, third and fourth)
    tyres are TKOs
    annoying.
    thoughts?
  2. Nov 9, 2011 at 4:35 PM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Block has nothing to do with the sound. You prob have a bearing going out, isolate the sound to a side and go to work.
  3. Nov 9, 2011 at 4:46 PM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Seen. Just giving an idea if someone thought it may have to do with the driveline angle.
  4. Nov 9, 2011 at 4:47 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    That's it right there. Edit: A body lift doesn't affect you suspension geometry just how high off the frame the body sits.
  5. Nov 9, 2011 at 4:53 PM
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    do this....... lift up one side and put it on drive and let one of the rear tires spin in the air, hear for something, if you cant hear nothing try the other side.
    I had a vibration problem and it also hummed until i found out it was my u-joint, small things are really noticeable and the most annoying ones because you imagine it to be a huge problem.
  6. Nov 9, 2011 at 5:01 PM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Id rather let the dealer do this at next oil change (first 6 free) since its under warranty but fear they will dismiss it due to modification.
  7. Nov 9, 2011 at 6:17 PM
    SampleFool
    Ga
    Silver
    08 off-road
    You are ballzy, I do the same thing but use the shops lift with both wheels up.
  8. Nov 9, 2011 at 9:23 PM
    TROKITA
    Arty
    Utah, the valley
    it can be done like that to but sense the two wheels are up one is going to spin faster then the other one and you wont know if its the left or right wheel, baring, or shaft.
