Rear bearing help.
Discussion in '1st Gen. Tacomas (1995-2004)' started by chrslefty, Nov 3, 2020.
  1. Sep 25, 2022 at 7:39 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Those are both ABS axles in my pic above.
    I agree with you on not flipping the inner retainer ring. Just press it on slightly, and check where it's running on the seal with a little grease. Easy to press on further if needed.
  2. Sep 25, 2022 at 9:28 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah I took that new ring, inserted in the new seals week ahead of time...let them loosen up/condition...
    even stuck in deep freeze last 24.....
    Everything slid together well, two months out and no leaks......
    If get it wrong, not that hard to redo......however probably cost you a set of pads though.....
    I dont put many miles on mine a year... 5K or 6K..so it will be a long time either way for me....
    That seal redesign hasnt been out that long......we'll see....
    It looks like the 4-runners found this problem quick...
    Pure daily commuters maybe immune from this....
    I can tell you this......at 170K mine on a rwd... just starting to leak......
    unless that was residue from when they broke in....
    I do keep an extra one of those seals handy......because of that......I'll never need the SOB......
  3. Sep 25, 2022 at 9:36 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    The Timmy vids are great. If you also want something you can print out as a step-by-step, this is a good walkthrough of the process, so you aren't constantly trying to jump to/pause the video, etc. as you do the work. Also has the full list of parts/tools/SSTs, etc. As others have said - the SSTs cost a bit of money, but at least for me (PNW), even purchasing them to do the job once would have been cheaper than having a shop do it. And the job isn't hard, it just requires precision with some of the pressing.
    Step-by-Step Replacing Rear Axle Seal & Bearing w/ABS (1st gen Tacoma or 3rd gen 4Runner)
    15psd likes this.
  4. Sep 25, 2022 at 1:32 PM
    Dare Devil Diablo
    Dare Devil Diablo Well-Known Member
    2000 TRD Offroad MT
    Ya, I already bought the tool. I've done wheel bearings in the past a bunch of times with zero instructions or special tools. The ol Dremel and chisel works a treat. Then use the old split race and a BFH to seat the new one. Now I have a press and the axle bearing tool. This will be a breeze.
