Rear Billies 5100 max out...
Discussion in '1st Gen. Tacomas (1995-2004)' started by markvfr, Feb 16, 2009.
  1. Feb 16, 2009 at 7:41 PM
    markvfr
    markvfr [OP] Member
    Calgary
    02 Tacoma TRD Xtra Cab
    Bilstein 5100
    Hi,
    My first post, after searching for awhile on my issue. Great site btw.
    I just installed the rear Bilsteins 5100s yesterday and noticed this... see pics. The shocks seem to be maxing out on the travel. There is absolutely nothing in the box (no extra weight). I had no choice but drive home 200 miles on this to get home today.
    I don't know how to embed pics so here are the links.
    [​IMG][​IMG]
    Could you explain what/how to remedy this and what is going on? I've read something about bumpstops on here... What are they?
    Sorry for the dumb questions, but I have wrenching experience on motorcycles but haven't been working much on my truck. :rolleyes:
    I ordered these from Sonny at Downsouth and he didn't mention anything about bumpstops. He said they would work exactly the same as the OEM HDs. I just wanted straight OEM replacements and the 5100s were cheaper than the HD, thus thats what I got.
    Any help would be appreciated. I'm a little worried.
    Thanks.
    Mark
  2. Feb 16, 2009 at 8:48 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    are you saying there fully compressed? thats what they look like to me.
    bumpstops are just rubber pieces mounted to the frame to keep the axle from comming up and hitting the frame.
    Make sure you ordered the right travel shocks. Looks like you may have ordered shocks too long (2wd?) for your truck.
    Who put them in? were they a fight to get in? More explanation would be good.
  3. Feb 16, 2009 at 8:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Looks like they are too long.
  4. Feb 17, 2009 at 6:19 AM
    markvfr
    markvfr [OP] Member
    Calgary
    Bilstein 5100
    Thank you for the bumpstop explanation. :)
    Yes, the shocks are fully compressed. I put them in myself. The OEMs were a bit of a struggle to get off but it wasn't a problem putting the 5100s on.
    I'll email Downsouth motorsports and ask if I got the right shocks.
    Thanks.
    Mark
  5. Feb 17, 2009 at 7:47 AM
    markvfr
    markvfr [OP] Member
    Calgary
    Bilstein 5100
    Ok, I talked to Sonny this morning and it appears that I got the right shocks but I need an ad-a-leaf (Fabtec) to compensate for the sag and wear of the original leafs. This should get it back up to original ride height. This would also explain why I had a tough time getting the old shocks off the truck. They were under tension because of the leaf fatigue. I haul dirtbikes on my truck all the time, thus I'm not surprised I've worn the springs so much. Apparently the 5100s are an inch to inch and a half longer in the compression compared to the stock Bilstein HDs.
    As to the front now... After I ad the leaf on the rear, I was going to leave the front struts at the stock clip setting since the rear should be back to normal ride height. Has anyone raised the front in this situation? A suggestion is that I raise the front to the 2.5" clip to level out the truck. Would that work?
    Any opinions would be greatly appreciated.
    Thanks.
    Mark
  6. Feb 17, 2009 at 10:13 AM
    markvfr
    markvfr [OP] Member
    Calgary
    Bilstein 5100
    Another solution might be that I return the 5100's and order the OEM Bilsteins HDs and combine them with the Fabtech add-a-leaf.
    Thoughts anyone?
  7. Feb 17, 2009 at 4:57 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    sounds like your going throu alot of frustration for nothing.
    Dont order an AAL for new shocks...I put billstien shocks in the rear of my truck at around 70K and i didnt have any problems. Something just isnt sounding right with your setup.
  8. Feb 17, 2009 at 5:39 PM
    markvfr
    markvfr [OP] Member
    Calgary
    Bilstein 5100
    I know! Its feeling like it. However, I just checked the shock part # and it matches with what it should be on the 5100s on the Downsouth website: "BE5-D559-TO" Drivers rear and "BE5-D560-TO" passenger rear. So, it looks like I have the correct shock, but the shock is fully compressed. So, I had a closer look at my springs and they are looking pretty "tired" ie flat! This means that they're not carying much weight. I did order an AAL as I can't really afford a whole new set of leafs ($500 a side). Will see if that helps. Like I mentioned before, I do haul stuff all the time and used to haul my 500lbs streetbike a lot a few years back and since then two 250lbs dirtbikes... its not easy on the leafs I imagine.
    What Downsouth motorsports also did is, they're sending me a set of stock Bilstein HDs to see if they work better with the AAL. Sonny has been great to deal with. It just sucks, 'cause I don't want to drive the truck right now, and the parts won't arrive 'til the weekend. Ugh.
    I don't know what else to do besides getting a new set of springs...
  9. Feb 17, 2009 at 6:01 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    looks like there ment to a lifted truck. you could just get some blocks, or shaqs. up to you but yeah im thinking thouse are forr a 3in lift.
  10. Feb 19, 2009 at 8:26 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    I have same problem man. I just got TSB done and then put on the rear 5100's. Since the install I have hauled my quad twice and it has been worse then before the TSB and 5100's. The leafs are now sagging and it sounds like my rear shocks are bottoming out.
  11. Feb 19, 2009 at 8:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Interesting. With a 4 adults in my truck, loaded tool box, large full cooler, and my boat hitched up, my truck is nowere near bottoming.
  12. Feb 19, 2009 at 9:26 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    On the rear of my truck I have more of an issue with 'topping out' the shocks than bottoming them. I get a bang or thud once in a while when one side drops over a mound or dirt or whatever. Under mine I have the TSB springs and a 1" block, AAL soon to come. I don't want to ditch my 5100s but with the AAL under there its just going to get magnified even more......
  13. Feb 19, 2009 at 12:32 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    lucky... Well when we meet up for "phoenix mod day" I will check out your set up. :D
  14. Feb 19, 2009 at 1:33 PM
    markvfr
    markvfr [OP] Member
    Calgary
    Bilstein 5100
    Yes, exactly the same. When I put the 5100s in, the rear is sitting lower now, then before with the HDs and the leafs look more saggy... Something is definitely not right. I'm surprised no one else has had this issue (beside us two), especially with how much the shocks are compressed. And this is on a 2002 TRD 4X4 with 70,000 miles on the clock... its not like its a dinosaur of a truck...
    I dunno. The AAL might not arrive by the weekend, so I'm SOL for another week. Sigh.
  15. Feb 19, 2009 at 2:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmmm.....My 5100's make no such "Thump" when dropping the axel. :confused:
    I have heard of this happening before, though. Personally, Im switching to the OME rear shocks when I get a job.
  16. Feb 19, 2009 at 3:16 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    is this for the 2nd gens? im about to order the 5100s for my 96:confused:
  17. Mar 24, 2009 at 9:47 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
  18. Mar 24, 2009 at 10:03 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    My 5100s look like this with stock height Alcan springs:
  19. Mar 25, 2009 at 3:36 PM
    Youngunner
    Youngunner Well-Known Member
    Yellowstone National Park
    2003 Tacoma
    The standard expedition setup...
    It has to be your springs. Sure is a lot of rust on the bottom of your rig! That probably doesn't help. I have the same part number shocks on my 03 and have no problem, even with stock springs. I went ahead with AALs and everything was great. I wouldn't settle for anything less, especially if you are hauling. I was informed that the boot faces the ground on these particular shocks, FYI.
  20. Mar 25, 2009 at 3:47 PM
    Bing0
    Bing0 Member
    02 4WD Limited Icons
    Icons, Cepek Rims, Bilstein Rears, Deck plate mod, Complete Sound Deadener with foam, GPS Kenwood
    This is how mine look too except I took out the overload springs.
    I have the Alcan AAL which is manufactured for Wheeler's Offroad.
    I had a big debate with the installer that the OL spring needed to be removed. He countered and we left them in. I wanted the setup to be the best that it can be which in my opinion is not installed based on the opinions of technicians.
    I trust engineers. I also see a red flag go up when I hear a technician say anything disparaging about engineers, ...especially when an installation decision arises.
    Well I called Wheeler's and they told me that these leafs are NOT designed to be used with the overload spring installed. Yes some carrying capacity is lost but what is gained is really awesome articulation and ride quality. These are progressive leaf packs and the overload spring being in there with them is incorrect.
    I went back to the shop and had the overload springs removed.
    This is a perfect solution because I still don't know if I am going to need to do that anyway.
    There is the real concern that the loss of bed capacity might be a problem. I found that there is a complete resolution for that issue which can be remedied by installing Timbren bump stops.
    This is something I will do later on if need be.
