Rear Bilstein 5100 question
Discussion in 'Suspension' started by All Beef Taco, Jul 13, 2010.
  1. Jul 13, 2010 at 5:18 PM
    All Beef Taco
    All Beef Taco [OP] Well-Known Member
    Joe
    Thornton, CO
    2010 TRD Off-Road DC 4x4
    Rattle canned wheels, Weathertech Floormats, Undercover Tonneau, DIY Hi-Lift jack bed mount, Demello Sliders, ARB Bumper w/ ARB Fogs + anytime fogs mod, IPF 968's, Warn M8000 w/ Amsteel Blue & Billet 4x4 Hawse Fairlead, Rear Leaf TSB, Toytec Adjustable Coilovers and AALs, Rear Bilstein 5100's, BFG MT KM2's, Safari Snorkel, Rear Diff Breather Mod
    I just got my rear 5100's after a long wait for my backorder to come through. There is a set of hardware included with each shock and I'm not sure about how to properly arrange it. Specifically, there are a 2 rubber bushings and 2 steel washers along with 2 rubber washers and a nut-- do I have to use all of them and in what order? The nut is obvious but I wasn't sure if all the other hardware is needed or what. I didn't see this part covered in any of the installation threads. Any tips would be greatly appreciated!
  2. Jul 13, 2010 at 5:20 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    you put washer and a rubber bottom and a rubber then a washer on top
    hope thats helps
  3. Jul 13, 2010 at 6:04 PM
    All Beef Taco
    Joe
    Thornton, CO
    looking more closely it's actually 3 metal washers-- 2 stainless and one plain steel which I thought was a rubber washer.... not sure where that plain steel one should go.
  4. Jul 14, 2010 at 9:25 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    From the bottom of the stem. Large Washer, Bushings, Small washer with lip up, That goes through frame mount. Then on other side Bushing, Large washer, Nut.
  5. Jul 14, 2010 at 9:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    They are 2" in diameter, and have a 3.8" stroke. Not sure on the overall length.
  6. Jul 14, 2010 at 9:53 AM
    Rusty White Taco
    Rusty White Taco Active Member
    Central Coast, CA
    04 4x4 Xtra Cab TRD Offroad SR5
    Debadged, Front 5100s at 2.5, 1" rear shackle lift, 5125s in the rear, trimmed exhaust pipe
    The big question (for me) is, where did you get the 5100's? I've been searching and calling almost daily and nobody seems to have them for 1st gen or 2nd gen Tacos...
  7. Jul 14, 2010 at 9:55 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  8. Jul 14, 2010 at 10:57 AM
    All Beef Taco
    Joe
    Thornton, CO
    I got mine from shockwarehouse.com, but it was about a 2 month wait for the backorder.
    Dan, thanks for the help! One more question... the two thick washers-- one is black, the other is stainless. Does it matter which goes where?
  9. Jul 14, 2010 at 11:03 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    That's how long mine took from them too
  10. Jul 14, 2010 at 11:41 AM
    All Beef Taco
    Joe
    Thornton, CO
    Found a customer service number on the installation kit bag so I gave them a call and a nice fellow over in their tech department was able to describe them and tell me the proper order. So to any others out there, for future reference/if anyone else ever wonders:
    From bottom up:
    1) Stainless thick washer (has a small inset indentation along the radius of the hole) goes on first, against the shock boot.
    2) Bushing
    3) Thin stainless washer (has a small lip along the radius of the hole) goes on the underside of the frame
    4) Bushing
    5) Black steel washer
    6) Nut
  11. Jul 14, 2010 at 12:24 PM
    All Beef Taco
    Joe
    Thornton, CO
    Here are some pics... as you can see, there are three unique washers. A thick stainless one with a groove along the radius of the hole, a thin stainless one with a lip, and a black washer.
  12. Jul 16, 2010 at 6:29 PM
    Devildoc
    Devildoc Well-Known Member
    Lincoln, California
    Speedway Blue off road
    Running board, K&N air filter, Nitto Terra Grapplers G2 on ProComp 7089(285/70/17), 3" front lift and 1.5" AAl rear, all with bilstein 5100's with Eibach spring, 1/2 spacer in driver side and 1/4 spacer on the passenger, Wicked Flow exhaust, Debadge, satoshi raptor grille (HomerTaco)
    What a good info to know! I just had my rear spring tsb done and I am going to install the rear 5100 next. Was wondering the same thing. Thanks for the info. Do we need to get it align after after the install? May be there is no need.
  13. Jul 19, 2010 at 12:57 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No, not if you are just doing the rears.
  14. Jul 19, 2010 at 3:02 PM
    Devildoc
    Lincoln, California
    :) thought so, thanks!
