Rear Bilstein 5100
Discussion in 'Suspension' started by TacomaGRG, Nov 22, 2010.
  1. Nov 22, 2010 at 3:17 PM
    TacomaGRG
    TacomaGRG [OP] Well-Known Member
    Greg
    Danvers, MA
    09 SR5
    Westin Stainless Bull Bar Flowmaster 50 Dual Exhaust 17" FJ Cruiser Wheels Socks Devil Horn 3rd Brake Light Cover STK Pro Rack Carriage Works Black Billet Grille w/Devil Horns Stubby Antenna Avid Rocker Guards Rear Leaf TSB Rear Bilstein 5100s Front Bilstein 5100s @ 1.75 AFE Air Filter
    I just added front bilstein 5100 to level out my truck. I have the rear tsb in the back, is it worth it to get rear bilstein 5100s? Will I even notice a difference in the ride?
  2. Nov 22, 2010 at 3:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  3. Nov 22, 2010 at 3:20 PM
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    From my research you can.
  4. Nov 23, 2010 at 2:43 AM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    I felt an improvement in the ride when I installed 5100's all round, even at stock height. I don't think you'll regret doing it. It's super easy to do too.
  5. Nov 23, 2010 at 8:06 AM
    TacomaGRG
    Greg
    Danvers, MA
    09 SR5
    Thanks again Chris!
    Thanks for answering my next question. It looks easy to do but with anything you never know til you get into it. But this I think I can handle.
  6. Nov 23, 2010 at 11:22 AM
    BenWA
    BenWA Well-Known Member
    Seattle @ 0.9 Mach
    '06 Double Cab TRD Off Road 4X4
    It honestly shouldn't take more than 10 minutes per side to install the rears. The hardest part was getting the bushings of the lower shock eyelets to fit in between the trucks lower shock mount brackets. A little gentle persuasion from a mallet and a pry bar gets it in there though. I would suggest jacking the truck from the differential pumpkin, lowering the truck onto jackstands on each side of the truck's rear frame, take wheels off, then raise and lower the rear axle via the jack under the pumpkin to the appropriate work height needed to finagle the shocks into their mounts.
  7. Nov 28, 2010 at 10:25 AM
    bigmooze
    Richard
    Belle River, ON
    I put a light film of grease on the bushings to help slide them into the shock mount brackets.
  8. Nov 30, 2010 at 8:46 AM
    TacomaGRG
    Greg
    Danvers, MA
    09 SR5
    Thanks for the info guys. I just ordered rear billies.
  9. Nov 30, 2010 at 9:15 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Add some time for things being rusted on. If you've been through a few of the New England winters, hit the bolts up with PB Blaster about 30 minutes before you start, it'll save you a lot of swearing later.
  10. Nov 30, 2010 at 9:26 AM
    TacomaGRG
    Greg
    Danvers, MA
    09 SR5
    Thanks for the tip but I'm thinking I should be alright since they just took them off last month for the TSB. But it has been through 2 new england winters and I know what your talking about with things being rusted on around here.
  11. Nov 30, 2010 at 9:27 AM
    kws129
    kws129 Well-Known Member
    PA
    TRD Off Road Double Cab
    I actually did the exact same thing and had the exact same question. 5100's up front with rear tsb.
    Thanks to everyone for the replies.
    Where did you order your rears from?
  12. Nov 30, 2010 at 5:11 PM
    TacomaGRG
    Greg
    Danvers, MA
    09 SR5
    I got them from 4Wheelparts.com. They were like $157. shipped it was the lowest price I could find.
  13. Nov 30, 2010 at 6:23 PM
    xGManx
    xGManx Well-Known Member
    Garrett
    South
    06 DC LB
    black rims, blacked out grille, blacked out exhaust tip, 5100's 1.75" with 2" rear block, pioneer head unit
    Ive been researching the rear suspension TSB and ive recently noticed a lot of squeaking in my rear leafs, i have 5100's at 1.75" in the front with everything else stock. its a little high in the front, like .5", so my question is will the TSB rear spring repair level my truck out? and im covered by the 36k mile/36 month warranty btw
  14. Nov 30, 2010 at 8:23 PM
    TacomaGRG
    Greg
    Danvers, MA
    09 SR5
    I had the rear tsb done with front billies set at 1.75 and it has a slight rake but just about level. The tsb after settling will give you about an inch of rear lift. The tsb is covered under the 3 yr/36k warranty. Just tell your dealer the springs are squeaking and that your truck bottoms out with 500lbs in the bed, that is key. Good Luck.
  15. Nov 30, 2010 at 8:35 PM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    08 Rugged OffRoad TRD
    Hid headlights an fog lights, LED blinkers an brake light bulbs. anytime fog light mod, brighter reverse light mod, Access Vanish bed cover, color match grill, black rocker guard painted skid plate, rear TSB, 5100's with front set at 1.75, BF T/A KO 265/75/16, yo mama riding shotgun.
    Sorry I'm still new here but what is tsb?
  16. Nov 30, 2010 at 8:46 PM
    TacomaGRG
    Greg
    Danvers, MA
    09 SR5
    Its like a recall. I think it stands for Technical Service Bulletin. Just search rear leaf tsb on here, there are a ton of threads.
  17. Dec 1, 2010 at 5:23 AM
    xGManx
    Garrett
    South
    06 DC LB
    thanks dude, since im under warranty the dealer will pay for it correct?
  18. Dec 1, 2010 at 10:36 AM
    TacomaGRG
    Greg
    Danvers, MA
    09 SR5
    Yeah it was free.
  19. Dec 2, 2010 at 8:57 AM
    xGManx
    Garrett
    South
    06 DC LB
    awesome:D
  20. Dec 3, 2010 at 6:31 AM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    How much does the Tsb cost if your out of warranty?
